Complete Module Ideas
08/20/2014 at 17:00 • 0 commentsMy initial thought was to simply include the electronics required to attach the Wii to an arduino or other microcontroller. This has been evolving in my mind to include a version that outputs directly to two servos. This would make the module very useful for canned applications like camera/sensor tracking.
It will not be difficult to produce this additional module pre-loaded with the required code. Some inputs such as PID values and sensitivities will need to be included. Either a USB or LCD interface would be required. This is all very do-able and would be really useful particularly for art or video production projects.
One immediate thought is that it would be useful for projects like this:
The skydiver would simply need to have a IR LED to allow for tracking, although the sun might be an issue at times. There may be ways around this as the Wii IR camera outputs the 4 brightest points. The sun may be disproportionally brighter and able to be ignored.
Old Circuit
08/20/2014 at 16:45 • 0 commentsAs a reference I've added an old circuit diagram where I was working out how the single sided board will be laid out. I have since graduated to using Eagle and will need to transition the schematics.
Applications: Sun Based Rocket Guidance
08/20/2014 at 16:43 • 1 commentI used to do a fair amount of hobby rocketry. I've since moved on to building my own rocket engines and publishing on rocket engine design. I was always interested in more advanced methods. One report that got my attention was this:
It is available here: https://blastzone.org/nar/narts/ This report uses an arrangement of photocells in a control system to guide the servos.
The Wii camera can track the sun as well. We can use this to accomplish the same task, but in a slick new way (of course, the old way is really nice and elegant which is awesome too).
This is where my Wii Rocket has come from. It has yet to fly, but it is close. Don't worry, this can't be used for anything nefarious. The Wii camera is not heat-seeking. That is very low frequency (long-wave) IR. The Wii camera views near-red infrared (short-wave). Infrared covers a very large frequency range so it is important to clarify what type of IR you are talking about. The sun works for tracking because is it blasting out a whole range of light.
I will add updates as this continues.
The Code
08/20/2014 at 16:27 • 0 commentsThere are some very kind nice people out there that make you love the internet. Most of the software had been figured out prior to me building this. I initially made a tutorial hoping to put together all the resources into one place. I have all the details (and all the links should still be good) in the instructions.
Two Servo Setup
08/20/2014 at 16:19 • 0 commentsI've expanded upon the existing setup to add 2 servos. The takes data from the Wii IR camera (short wave IR, like that in IR LED's, not body warmth which is long-wave). This can be used for a camera tracking system. A simple IR LED can be added to a target and the camera will follow the target. Very little computing power is needed.
Instructions Complete
08/16/2014 at 17:01 • 0 commentsI have added the instructions on how to interface the Wii Camera to an arduino. As you can see in the videos, there is a really rapid response time. Perfect for robotics tracking.
I have had some feedback from individuals that had a hard time getting this to work. I am now looking (inspired by the contest) to develop this into an open source module that will be more plug and play.
Eric Jacob
