A little two wheeled diferential robot with SLAM
I didn't updated this page because my final project was changed a bit, but I'm going to update it in a few months with my results explained and the code.
I'm working from scratch, for learning purposes. I'm using an Extended Kalman Filter with landmark extraction from raw data from LIDAR.
Did you manage to implement slam algorithm?
