In the next few days I'll be putting in an order for about 100 CC254X modules to build a batch of prototype boards. This is most an experiment for me to see how easy, or not, it is to do a "small batch" run. I've been negotiating with various people on Alibaba because that seems the cheapest place to get the core module, but I admit to being somewhat nervous about handing over $400 without understanding the risks involved. Anyone have any insight or experience here?
I wouldn't say no to help with a .NET version. The communications protocol is brain damagingly simple so I can quickly write that up. The firmware upgrade one is slightly more complicated (although not by much) but is the standard one TI uses.
Also the offer I made you previously about helping with a .NET port of your console is still there - my HM-10 module should arrive in week's time and I'll be keen to try out your bluebasic (in fact also thinking the same approach of using tinybasic interpreter would work even better for zigbee modules).
