- System diagram
- Internal operation of the spectrum analyzer
The analyzer has the classic structure with a local oscillator, mixer and IF system. The Si4012 is used as local oscillator, it generates up to 960 MHz and has a two-wire control interface. The mixer is a Maxim 2680. The Si4431 is tuned to the IF frequency (with selectable bandwidth) and provides a logarithmic signal strength indication.
The Si4431 can be tuned to 960 MHz maximum, this would give a maximum receive frequency of 960+960 = 1920 MHz. But we can also use the 3rd harmonic of the oscillator, this theoretically gives a maximum receive frequency of 3840 MHz.
For a given receive frequency, mirror frequencies are suppressed in firmware by using two or more combinations of LO and IF frequency. The wanted frequency will be present in all combinations, mirror frequencies are only present in a single combination.
The sweep time is set automatically by the firmware, as a function of the SPAN and the RBW.
- Other functions
Several wireless communication systems use short pulses, that might be hard to detect on a spectrum analyzer. To detect these, the analyzer has a ADL5519 power detector that works up to 6 GHz. The power detector is sampled at 20KHz, so it will detect short pulses without the need to be tuned to a certain frequency. It also has the ability to measure the frequency of the pulses (under most circumstances with 100MHz resolution), this is described in one of the project logs. The input is switched between the spectrum analyzer and the power detector with a AS186-302 switch chip.
Every 10 seconds, the maximum output level of the power detector and the detected frequency are written to a micro-SD card. A realtime clock is present to provide date and time stamps to the logfile. The logfile is readable on the device itself, but can also be read with excel (CSV format). Every new day, a new directory is created for this day and a new logfile is created. Every month, a new directory is created for this month that contains the directories of the days.
The micro-SD card can also be used to upgrade the internal firmware.
The output of the power detector can be directed to the internal speaker, so you can hear the wireless communication pulses. The sound is generated by the DAC output of the microcontroller, with the same 20KHz sample rate. Volume control is done in the firmware. Sound can be output through a 3.5mm jack. The second channel of this 3.5mm jack can be used as analog input, or as a half duplex RS232 communication port.
A microphone is available. I want to be able to record spoken comments (and store this on the SD card) while measuring, but the firmware for this sound recorder is not yet working.
The device is powered by two AA batteries, or two NiMH cells. An adapter can be connected to charge the NiMH cells.
- low-frequency electric and magnetic fields
Many people have health problems due to exposure to RF radiation (see mast-victims.org). These people can also be sensitive to low-frequency electric and magnetic fields. For this reason, the device can also measure these low-frequency fields. The waveform is displayed on the screen, and can be output at the speaker. 20KHz sampling is used. Every 10 seconds, the measured value is written to the logfile. The same functions are available for the analog input (AC value is measured, DC value could also be measured).
- User interface
Only the most important user-interface functions are mentioned in this section.
After switching ON, you can choose between the following modes:
- SCAN (Spectrum analyzer)
- RF (Power detector)
- ELEC (electric field)
- MAGN (magnetic field)
- MENU (Utility functions: inspect SD card, set time and date)
The spectrum analyzer mode displays the following values:
- In PK (peak freq) mode: measured level and frequency of the detected peak
- In CF (center freq) mode: level and frequency at center frequency
- Start and Stop frequencies, Span, RBW (Resolution bandwidth)
- Graphic...
Robert Gawron
Pero
Grant Giesbrecht
Form factor for me is not essential. 12in H X 5in W (30.48cm X 12.7cm) would also work and allow for a larger display.
