Using 74HCT273 for registers
05/31/2017 at 22:48 • 0 commentsAfter some research, I am changing my mind and inclined to use the 74HCT273 (*) as registers.
I need the Reset input and the 3 state output.
There will be:
- 4 chips for IR register (32 bits);
- 2 for PC (16 bits);
- 8 for general use registers (8 bits each).
So I'll need 14 of these guys., so far..
(*) Edit: It's not 74HCT273, the right IC is SN74ALS874BN, not very easy to find on stores, but will save many ICs, since it's the only with both Reset and 3-state outputs.
Instruction ST A, [addr] and research to 2nd gen CPU
05/25/2017 at 19:41 • 0 commentsStill lacks the ST A, [addr] instruction, to save the contents of tha A register to the RAM (actually, the register has only 4 bits and each RAM cell is 8-bit, so it uses just the 4 less significant bits, and the other bits are set to 0, kind of odd, I know, but it's just a proof of concept).
I'm procrastinating a lot this last instruction, because I'm deeply buried in TTL research to the 2nd generation CPU, JACA-2...
Let's see what I chose so far:
-2x 74181 for ALU
-for registers: 74HC574
-for RAM: CY62256
What do you think about these choices? Would you use others?
