Robotic arm can perform diffrent task which can be programmed by entering input via the prototype arm.
process.docxMicrosoft Office - OOXML - Word Document - 4.27 MB - 05/23/2017 at 06:08 |
arm.blendblend - 586.96 kB - 05/23/2017 at 06:07 |
robotic_arm.blendblend - 936.48 kB - 05/23/2017 at 06:06 |
source_code.inoino - 11.35 kB - 05/23/2017 at 06:06 |
README.mdmd - 846.00 bytes - 05/23/2017 at 06:06 |
making robotic arm -
⦁ Take the wooden piece A (10cm x 3cm) and glue the body of a servo motor to one of its ends.
⦁ Take the wooden piece B (13cm x 4cm) and drill two holes of the dimension 22.2mm x 11mm along the length of the wooden piece separated by 70mm apart.
⦁ Insert the servo motors to the holes in opposite directions.
