1Step 1
making robotic arm -
⦁ Take the wooden piece A (10cm x 3cm) and glue the body of a servo motor to one of its ends.
2Step 2
⦁ Take the wooden piece B (13cm x 4cm) and drill two holes of the dimension 22.2mm x 11mm along the length of the wooden piece separated by 70mm apart.
3Step 3
⦁ Insert the servo motors to the holes in opposite directions.
4Step 4
⦁ Take the wooden piece C (9cm x 2 cm) and fix another servo motor using super glue at a distance of 20 mm from one side.
5Step 5
⦁ Glue the propeller of servo motor of wooden piece A to the wooden piece E at any corner.
6Step 6
⦁ Glue the propeller of one of the servo motors of wooden piece B to wooden piece A leaving 15mm from top.
7Step 7
⦁ Glue the other propeller of servo motors of wooden piece B to wooden piece C leaving 5mm from the servo motor attached to wooden piece C.
8Step 8
⦁ Glue the propeller of the servo motor attached to wooden piece C to wooden piece D from one of its ends.
9Step 9
⦁ This whole apparatus would be the robotic arm.
10Step 10
Steps to build the prototype arm-
