PCBs!!!
06/13/2017 at 18:44 • 0 commentsToday I receive my package:
Some errors ( :( )
- wrong position of LCD pads - should be more in right and down position
- soldermask on "buttons" - but I can easy fix this
- a little different pinout to jack plug, but it is still ok to solder
Quality of PCB - GREAT! :)
STM32F0 dev board
05/26/2017 at 11:20 • 1 commentUnfortunately - only one output pin (on jack), but we can also use SWDIO and SWCLK. Order from China so I need to wait 3-4weeks to test it.
Eagle PCB template
05/25/2017 at 00:17 • 0 commentsI've created schematic and board with all important elements on its positions:
Eagle files: https://github.com/dambo1993/chinaMP3hack
Hack a LCD
05/25/2017 at 00:08 • 1 commentThe most valuable from this device is of course LCD. But first I didn't know what controller is in it.
Simple debug connections:
Problem with connection to saleae:
At this point I can copy value from uc to LCD and retransmit it, buf then I've found this site:
http://overskill.alexshu.com/cheaphack-a-2-5-chinese-mp3-player-for-its-128x64-mini-lcd/
with explanation about LCD type. It is UC1701. We cen use arduino library u8glib to play with it.
As display PCB I use universal board for uC:
So I can easy connect LCD to breadboard.
MP3 Player dissassembly
05/24/2017 at 23:54 • 0 commentsWhat can we find in 2 dollars MP3 Player:
- nice custom package
- graphic lcd (uc1701) 128x64px
- Li-Po battery (I think ~100mAh)
- USB connector
- Jack 3.5mm connector ( Mouser #161-3334-E )
- SD card slot
- on/off switch ( https://www.sparkfun.com/products/10860 )
- membrane keyboard
- asic for mp3 player (I think useless)
For 2 dollars!
