FireBreakNet
An affordable wireless sensor network that acts as a wildfire early warning system
Uncontrolled wild fires are a major problem in Southern Africa. These veld fires kill many humans and animals, and destroy infrastructure and tens of thousands of hectares of grazing, crops, and environmentally sensitive areas every year.
The FireBreakNet project aims to develop low cost, easily deployable wireless environmental sensors that can provide early warning in the event of veld fires. This would allow farmers, fire fighters and game rangers to respond quickly and efficiently to fires as soon as they start, preventing major damage and loss of life.
The Problem
Out of control wildfires can be a major problem worldwide, and especially so in my native South Africa. Between 2010 and 2014, a total of 118 952 veld, forest and agricultural fires were reported in South Africa, with estimated financial losses of R 194,653,000 (US $ 15,000,000). There was also a increase in reported incidents of 68% between 2010 and 2014. Although newer statistics are not available, the number of incidents during the drought of 2015-2017 (the worst in decades) will probably be even more shocking. In many cases the causes are unknown, but where it could be determined the top causes were human negligence, arson and lightning.
Fire fighting services are severely lacking in resources and manpower in South Africa, so farmers and farm workers are often left to put out fires themselves, with their own equipment. Farmers often struggle to make ends meet financially and receive little or no help from the government, so the expensive commercially available fire detection systems are simply not a viable solution for most.
Project Goals
Develop a network of wireless sensor nodes that detect when a veld fires start, provide early warning and reduce response time.
If veld fires can be detected early enough while they are still small, they can be extinguished early, thereby preventing major damage to grazing, ecologically sensitive areas and infrastructure and possibly save the lives of people and animals that would have been caught in the path of the fire. The sensors nodes can be deployed easily to vulnerable areas and provide constant environmental monitoring.
To be viable, it would have to meet the following requirements:
  • Accurate: It must should be able to detect the presence of fire quickly as possible, without giving false alarms
  • Low Cost: It must be affordable to the people who need it
  • Easy to deploy: It should not require advanced knowledge or extensive work to deploy and use.
  • Low power: The system must be able to run on small solar cells and batteries for years at a time.
  • Rugged: The system will have to endure the harsh African environment for extended periods of time.
  • Scalable: The system must work for any number of sensors, even for large game reserves that can be tens of thousands of hectares in size.
Basic Concept Overview
Each node would consist of a range of temperature, humidity, gas, particulate and optical sensors that would detect the presence of smoke and/or flames. This combination of sensors would most likely be required for accurate detection. The nodes each connect to a collector via a long range Sub-Ghz radio connection.
Each of the collectors (which can also be sensor nodes) then send their data to the cloud, either through a central hub, or directly via a GSM connection if it is available in the area. Remote end user devices can then view the data from the cloud, and receive fire alerts.
Licenses
TODO
  1. Range tests for Feather and TI modules.
  2. Complete software for testing, integrating all sensors
  3. Test and document power consumption for relevant components
  4. Select appropriate power source.
  5. Design and build modules and base station for field testing.
  6. Deploy prototypes to field to gather baseline environmental data
  7. Expose system to fire conditions to gather data for accurate detection.
  8. User interface and cloud integration
  9. Design and build pre-production prototypes and deploy at different pilot sites during fire season for continued refinement
FireBreakNet Business Plan.pdf
First Business Plan Draft
Adobe Portable Document Format - 56.87 kB - 07/24/2017 at 00:42
Preview
View all 11 components
  • Business Plan
    Danie Conradie • 07/24/2017 at 00:50 • 0 comments
    The first draft of my business plan has been uploaded under the files section as part of the Best Product entry requirements.
    It is the first business plan I ever wrote, and the experience was very rewarding. I used this template to get a rough idea of what questions I should be asking myself. I also found the Virgin Startup Business Plan Template to be a valuable resource
  • Logic Overview
    Danie Conradie • 06/12/2017 at 01:27 • 0 comments
    Below is a simplified flow of how data will be collected and handled. If a large enough data set can be collected during testing, a simple machine classifier like Naive Bayes can be implemented to determine the likelyhood of fire from the collected data.
  • Enclosure
    Danie Conradie • 06/12/2017 at 00:45 • 0 comments
    I've drawn out a basic concept for the enclosure in OnShape
    The enclosure consists of 4 main parts.
    The base slides onto the metal bracket, and has a opening in the bottom for the humidity, gas and particulate sensors to sample the air without directly exposing them to sun or rain.
    The bracket would be a simple piece of bent aluminium or galvanised steel flat bar, that can be mounted to any tree, pole or post with screws.
    On top of the base is the a transparent ring that allows light to reach the optical sensors on the inside.
    The top cover sits on top of the transparent ring. and has a angled top surface to mount a small solar panel. The top cover can rotate and then be fixed in optimum position for solar panel efficiency. The solar panel also helps to shield the optical sensors from direct sunlight, which can cause false readings.
    The base, and top cover will be injection moulded from a UV resistant polymer. The translucent ring will be injection moulded from poly carbonate. The seams between the parts will be sealed with o-rings. A single bolt will screw in through the base into a threaded insert in the top cover, pulling the assembly tightly together.
    IP53 will be the minimum ingress protection rating. (Protected from limited dust ingress, water spray less than 60 degrees from vertical)
  • The horrifying reality
    Danie Conradie • 06/11/2017 at 21:48 • 0 comments
    This past week, South Africa got a very nasty reminder of just how bad wild fires can be. Had this been detected early on, lives could have been saved and millions of dollars of damages could have been avoided.
    The area around the small coastal town of Knysna, Western Cape province, South Africa was engulfed in fires spreading from the surrounding forest and veld into the town itself. Large portions of the historical town has been destroyed and at least seven people have been killed so far.
    The cause has not been officialy established
    More pictures: https://twitter.com/vwsfires/media
  • Sensors
    Danie Conradie • 06/07/2017 at 21:38 • 0 comments
    I will be testing a range of different environmental to hopefully find the optimum trade off between cost and reliability for this project
    Temperature/Humidity/Barometric Pressure
    On their own these three parameters would not detect a fire accurately (unless the node itself catches fire or is very very close). Some of the other sensors I will be testing are affected by these variables, so keeping track of them is critical. It would also allow the node to gather general environmental data. The first sensor I tested is the DHT22 temperature and humidity sensor. It is commonly used in DIY projects so there are libraries and tutorials available. It was easy to get working, but after some research it is evident that it is not the most accurate or stable sensor. This excellent in-depth review compares many of the different sensors convinced me to try the Bosch BME280. I have ordered a some modules from Ebay, but they will take some time to arrive.
    Smoke/Particulates
    I will also be testing at least 1 particulate sensor. I ordered a Sharp GP2Y1010AU0F dust/smoke sensor . According to the datasheet the maximum current consumption is 20mA, and it should be able to distinguish between dust and smoke, although this will have to be confirmed during testing.
    Carbon Monoxide
    One of my main challenges appears to be finding a low cost, low power Carbon Monoxide sensor. I ordered MQ-7 CO sensors without thinking, since they are so popular and cheap. After looking at the datasheet and a quick test I realised that it is too power hungry for my battery/solar powered nodes. Testing confirmed it consumes about 200mA, and requires 1 minute to heat up before readings stabilise. I found that most of the other CO sensors are extremely expensive. My goal is $20 max for the sensor, preferably less.
    CO sensor options I have found so far:
    Infrared radiation
    The last sensor type I will be testing is optical IR and near-IR sensors. These will be used to check for the actual radiation given of by the fire. I will be looking at a range of photo-diodes, photo-transistors etc. The selection of sensors available is extremely large, so it is going to be a challenge to find the best solution. I will probably resort to some more research and then get samples and test them. I have so far tested a cheap flame sensor module with a photo-transistor, but the range appears to be very short.
    TI Sensortag Integrated Sensors
    The TI Sensortag include (among others) an IR thermopile (TMP007), ambient light sensor (OPT3001), humidity sensor (HDC1000), and barometric pressure sensor (BMP280) which will all be used to gather data during testing. Unfortunately the TensorTags got held up in customs, but I will hopefully get them this week to begin testing.
    Any advice/suggestions are welcome!
  • Microcontroller and Connectivity
    Danie Conradie • 06/07/2017 at 14:00 • 0 comments
    For the initial development opted to use off the shelf modules wherever possible to allow quick prototyping on a breadboard and veroboard. I will also be testing various components with the aim of finding the optimum solution that is a trade off between reliability and cost.
    Microcontroller and radio
    I will be using Adafruit Feather 32u4 LoRa dev boards for initial testing. They were available form my local supplier, so I could quickly get my hands on them. The boards have a 868Mhz SX1272 LoRa radio module onboard, as well as Lipo battery charger. I have no experience with ARM boards, so decided to stick with the 8 bit ATMega version of the board for a start, which I have some experience with.
    The other MCU/radio combination I will be testing is the new Texas Instruments CC1350 Dual Band Wireless MCU. It integrates an ARM M3 processor, a Sub-Ghz radio, BLE radio, and an interesting low power 16 bit "Sensor Controller" processor on a single chip. This chip is also available in a version without BLE, as the CC1310. Although the learning curve to get this chip working for my purposes will be much steeper, I believe there is a lot of potential
    TI claim that the chip is extremely low power, as well as long range with the Sub-Ghz radio. The BLE allows for Over-the-Air updating from a smartphone/tablet, which can be very handy in the field. The on-board "Sensor Controller" is a very low power 16 bit processor that can function to independently check sensor inputs, and only wakes up the powerful ARM processor when absolutely necessary.
    I have ordered the CC1350 Launchpad Dev board, which I intend to use as a gateway node for testing, as well as 2 CC1350 SensorTag dev kits, which integrate 10 environmental sensors and a coin cell battery holder in a very small package. The SensorTags also allow add-on boards to be added on top of them. The TI website has some very detailed tutorials and examples which will hopefully speed up development.
    I must give some credit to Shantam Raj with his SUN Project. I was introduced to the CC1350/CC1310 chips while reading his project logs.
    GSM connectivity
    I am considering adding a GSM modem as a modular add-on to the sensor nodes. My motivation for not making this standard on every node is two-fold. Firstly it would increase the cost and power consumption. Secondly, the isolated areas that the nodes would be deployed in might not have GSM coverage. Where GSM is available, some of the nodes can have the GSM module installed, to allow that particular node to also act as a gateway for the other nodes within range of the Sub-Ghz radio.
View all 6 project logs
tony wrote 08/23/2017 at 15:21 • point
Hi Danie,
I live in Greece so I do have a great experience of what a forest fire is.Came up with the same idea and during my research bump into lackaday article of your project.Would love to contribute
Chris wrote 07/10/2017 at 11:55 • point
Hi Danie,
I'm also from South Africa and based in Stellenbosch. If you'd like to grab a beer and chat about a few things - let me know. I have a couple of ideas for the transmission/micros.
Regards,
Chris
Tindie wrote 06/23/2017 at 00:30 • point
Congratulations on being one of the Internet of Useful Things Hackaday Prize Finalists! Carry on the good work.
