Trying faster acquisition
10/14/2018 at 14:05 • 0 commentsThanks to PIGPIO, in c, that's going a bit faster: and I can get really faster:
some details on the peak.
Trying a pHAT​
10/07/2018 at 20:07 • 0 commentsPushing a AD7476 on a pHAT looks promising. 12 bits, 1Msps, let's see !
Testing with a SPI_CLK at 1MHz, with a 1khz beacon, getting 9.5khz from the ADC:
Humm.. not the speed I'd be expecting. Let's explore the speed of sampling (Fech, in orange) vs the speed of the SPI_CLK (in blue). Seems it's stuck at 10khz for the RPi:
That would come from the RPi SPI overheads, with large intervals between captures. The below has a SPI_CLK at 18MHz, with large overheads between words:
Now: just need to find out where to accelerate the spi =)
Beacons found in the wild !
01/13/2018 at 21:57 • 0 commentsOn another hand, I was in a coffee (called Ajami possibly), and I found a nice peak around 20khz:
Now, all I need is understand what is inside =)
For those curious, data and code are at https://github.com/kelu124/ultrasHound/tree/master/mobile -- feel free to come and play.
What's next?
06/11/2017 at 21:27 • 0 commentsA small proof of concept has been done so far. Some extra items are missing:
- Shifting back to the 32u4 to benefit from the SD card and standalone FFT -> I need to have the ADC go faster for the acquisition, and to get the data compressed a way or another for longer acquisitions, but that should be feasible.
- Developing a more simple GUI for the OLED screen: I should be able to know when the signals are being recorded, and, if possible, how the beacon is encoded.
- Saving: when a signal is detected, the data should be recorded to the onboard SD card.
- Mapping: with a timestamped data, I'd be able to map on a geographical map the location of the beacons, and why not have a collaborative map ?
- Spoofing: when a beacon is detected, why not send a louder signal saying "HEY GUYS I KNOW YOU'RE LISTENING SO HEY THERE!", to outpower the actual beacon?
Testing the electret capacities
06/11/2017 at 21:22 • 0 commentsPlaying around with the STM32, I wanted to test if the electret was capable of listening to 18 to 20kHz sounds... Indeed! I've created 18kHz and 20kHz wav files on the repo, then played those and tested with the FFT capacity: the two peaks are very well resolved ! You can see the jupyter notebook for the experiment.
The peaks correspond the beacons are using. This proves that it'd definitely be possible to have a small device tracking the ultrasound beacons on the road!
Next steps.. having a better looking GUI on the small system OLED =) -
Getting into ultrasound spying
06/11/2017 at 21:21 • 0 commentsI've been reading some more about ultrasonic tracking beacons, so I wanted to play a bit with those.. Hackaday even spoke about those http://hackaday.com/2017/05/04/ultrasonic-tracking-beacons/ !
The first step is to get a microcontroller, a micro, and we're set. The setup looks like this:
First, I've tried with a 32u4.. the limited RAM onboard was problematic. So I took something a bit more powerfull - a feather WICED - which I used to acquire bits of 160ms (see below) - ~ 8k points at 50kHz.Now, let's try and see if we can isolate a clear 8kHz signal : indeed - documented on github !
The only thing that bugs me is that the FFT libs for the WICED are not yet well developped .. si I can't definitely use the WICED as a stand alone so far. Dang.
Initial research
06/11/2017 at 21:21 • 0 commentsWhat got my eyes was the following in the press:
That's freaky. The worst thing is that having a cross tracking device can also help you in being tracked even though you're using anonymizing tools:
Before going into the details of the projects, I've been doing some research to understand what was at stake.
- Startup uses ultrasound chirps to covertly link and track all your devices
- Ultrasound Tracking Beacons Making Things Sort of Creepy For Consumers
- How to Block the Ultrasonic Signals You Didn’t Know Were Tracking You
- Beware of ads that use inaudible sound to link your phone, TV, tablet, and PC Privacy advocates warn feds about surreptitious cross-device tracking.
Some companies and framework using those are:
- Silverpush
- Shopkick
- lisnr
- Signal36
PS: for a bonus.. the future of advertising thanks to ultrasound tracking =)
