ADC Calibration
07/03/2017 at 03:46 • 0 commentsThe STM32 ARM Microcontroller has a special calibration value that is provided for each chip form the manufacturer. When using the ADC, you can be sure that the conversion is accurate and in this video, I sow you the code necessary to complete this calibration.
ADC Videos for the ARM Microcontroller
06/26/2017 at 01:57 • 0 commentsI just added two ADC videos to the instructions area. The first one gives an overview and introduction to ADC, specifically how it relates to the STM32 ARM Microcontroller. The second video shows the first circuit and the preparation of the first program.
Part 18 of the LCD Interfacing
06/26/2017 at 01:55 • 0 commentsCheck out the final part on interfacing the LCD with the ARM STM32 Microcontroller where I demonstrate how to set the cursor location.
Part 16/17 was added (Integers and Floats to the LCD)
06/15/2017 at 04:00 • 0 commentsParts 16 and 17 of interfacing the LCD is posted in the instructions. In Parts 16, I add a function to display integers on the LCD. In Part 17, the same type of function is added, but for floating point numbers. Now, all sorts of numbers can be shown on the LCD, like ADC conversions, counters, variables, etc.
Part 14 and 15 of the LCD Interfacing has been added to the instructions.
06/13/2017 at 05:57 • 0 commentsI just added part 14 and part 15 of the LCD interfacing. These parts get into the actual displaying of characters on the LCD.
Part 13 on Interfacing an LCD to the STM32 Microcontroller
06/08/2017 at 04:37 • 0 commentsPart 13 of how to interface an LCD to the ARM Microcontroller was just added to the instructions section. I first go over a few pragmatic steps to determine if the enable and character output is done correctly. I then go on to add the LCD to the circuit along with the connections to the STM32 microcontroller's pins.
