Hackaday.io Hackaday.io
Sign up Log in
Low power GPS tracker
GNSS car tracker with per module power switching, an attempt at tracking without draining batteries in hours
ximonximon
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
5.2k views
4 comments
25 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
5.2k
4
25
13
Team (1)
  • ximonximon
Join this project's team
  • CarTracker
hardware
ongoing project
gps
This project was created on 06/01/2017 and last updated 9 年前.
Description
The plan is to power down the gps and gsm modules and keep the arduino in sleep which is woken up by a interrupt signal from the accelerometer, this will turn on the gps module and watch for movement. Periodically the arduino will wake the GPS module to confirm it hasn't moved from within a configurable distance. Movements will be sent via SMS and posted to a logging service (TBD)
Components
  • 1 × SIM800L 2G GSM module with GPRS
  • 1 × NEO-M8N GNSS Module
  • 1 × ADXL345 Accelerometer module with interrupt output
  • 3 × RT8272 Buck regulator module
  • 1 × Arduino pro micro Arduino
Project Logs
Collapse
  • Parts have arrived...
    ximon • 06/19/2017 at 23:06 • 0 comments
    The arduino, gps, gsm, dc-to-dc and accelerometer modules have arrived, time to start playing...
  • Waiting on parts...
    ximon • 06/07/2017 at 08:54 • 0 comments
    Awaiting delivery of components, should arrive in approx 2 weeks...
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Filinto wrote 08/17/2017 at 06:10 • point
whats the plan if GSM network is not available ? write to an SD card ?
ximon wrote 09/25/2017 at 13:04 • point
I was originally planning to just use the latest location when a connection had been established, but it would probably be useful to keep a log of past locations. SD should be easy enough to interface to
Filinto wrote 08/17/2017 at 06:09 • point
nice. was attempting something similar.
Christoph Blank wrote 07/19/2017 at 07:52 • point
Awesome project! Curious to see your developments!
A low cost datalogger for digital instruments
Project Owner Contributor
Bluetooth Instrument Datalogger
r-scott-coppersmithR. Scott Coppersmith
The 2018 Hackaday Prize
Modular power generation system for powering and charging small electronic devices
Power Generation Modules
cole-bCole B
We interface an Arduino with an A7672S to build a GPS tracker that's fully functional.
A7672S with Arduino: GPS without Wi-Fi
electroscope-archiveElectroScope Archive
An irrigation system using the U1 board from InvIoT.com. You also need a 4 relay module and 24v power supply
4 zone irrigation timer
inviot-dimitri-synodinosInvIoT Dimitri Synodinos
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Low power GPS tracker", please tell us the reason.
Send message
Remove Member
