Well, I never posted any code for that project, because I forgot it, let's correct that:
Arduino Pro Mini 5V w/ ATmega328
OpenOpener :
dual swing-gate automatic gate opener
// pins definitions :
// D0 - USB Rx shunt M1 - A0
// D1 - USB Tx shunt M2 - A1
// D2 - BP stop - A2
// D3 - Remote Control - A3
// D4 - Relay M1A Rpi i2c SDA - A4
// D5 - Relay M1B Rpi i2c SCL - A5
// D6 - Relay M2A
// D7 - Relay M2B
// D8 - BP close
// D9 - BP open
// D10 - PWM M1
// D11 - PWM M2
// D12 - relay FlashLight
// D13 -
#define PIN_RELAY_M1A 4 // D3 relay board
#define PIN_RELAY_M1B 5 // D2 relay board
#define PIN_RELAY_M2A 6 // D1 relay board
#define PIN_RELAY_M2B 7 // D0 relay board
#define PIN_BP_STOP 2 // pin 2 for external interrupt
#define PIN_BP_OPEN 9
#define PIN_BP_CLOSE 8
#define PIN_REMOTE 3
#define PIN_PWM_M1 10
#define PIN_PWM_M2 11
#define PIN_FLASHLIGHT 12
#define PIN_CURRENT_M1 0 // analog A0
#define PIN_CURRENT_M2 1 // analog A1
// defines
//#define _DEBUG_BP
#undef _DEBUG_BP
// parameters:
#define DELAYINMILLISEC 4000
#define TIMEOUTMOTORINMILLISEC /*5000*/30000
#define TIME_INHIBIT_IMES_INMILLISEC 1000
#define MAX_OVERCURRENT_IN_AMP 3.0f
#define MIN_MOTOR_CURRENT_IN_AMP 0.2f // minimum value when a motor spins (failure sensor detection)
#define IMESARRAY_SIZE 10
// enum
enum OpeningStates {
INIT_OPEN,
OPEN_M1,
OPEN_DELAY,
OPEN_M2,
WAIT_OPEN_END,
END_OPEN
enum ClosingStates {
INIT_CLOSE,
CLOSE_M1,
CLOSE_DELAY,
CLOSE_M2,
WAIT_CLOSE_END,
END_CLOSE
enum RemoteStates {
STATE_STOP1, // 0
STATE_OPEN, // 1
STATE_STOP2, // 2
STATE_CLOSE // 3
// global variables
unsigned char StopCount;
unsigned char nextState;
boolean bOpening; // flag for opening gates
boolean bClosing; // flag for closing gates
unsigned long timeStartOpenM1 = 0;
unsigned long timeStartOpenM2 = 0;
unsigned long timeStartCloseM2 = 0;
unsigned long timeStartCloseM1 = 0;
boolean bStopNow = false;
float currentM1_inAmp = 0.0f;
float currentM2_inAmp = 0.0f;
unsigned char currentState = STATE_STOP1; // remote control state machine
unsigned char newState = STATE_STOP1; // remote control state machine;
unsigned long lastTimeCheck = 0;
unsigned long timeCurrent = 0; // check currents values from shunt resistors
int ImesCount = 0;
int I1array[IMESARRAY_SIZE] = {0};
int I2array[IMESARRAY_SIZE] = {0};
int modeM1 = 0;
int modeM2 = 0;
bool isM1Stopped = false;
bool isM2Stopped = false;
unsigned long timeStartFlashLight = 0;
boolean FlashLightState = false;
// setup:
void setup() {
// init globals
StopCount = 0;
nextState = 0;
bOpening = false;
bClosing = false;
// output pins:
pinMode(PIN_RELAY_M1A, OUTPUT); digitalWrite(PIN_RELAY_M1A, LOW);
pinMode(PIN_RELAY_M1B, OUTPUT); digitalWrite(PIN_RELAY_M1B, LOW);
pinMode(PIN_RELAY_M2A, OUTPUT); digitalWrite(PIN_RELAY_M2A, LOW);
pinMode(PIN_RELAY_M2B, OUTPUT); digitalWrite(PIN_RELAY_M2B, LOW);
pinMode(PIN_FLASHLIGHT, OUTPUT), digitalWrite(PIN_FLASHLIGHT, LOW);
// input pins:
pinMode(PIN_BP_OPEN, OUTPUT); digitalWrite(PIN_BP_OPEN, LOW);
pinMode(PIN_BP_CLOSE, OUTPUT); digitalWrite(PIN_BP_CLOSE, LOW);
pinMode(PIN_BP_STOP, OUTPUT); digitalWrite(PIN_BP_STOP, LOW);
pinMode(PIN_REMOTE, INPUT);
// Serial link
Serial.begin(9600);
Serial.println("OpenOpener");
// interrupt pin for "remote control" input pin
attachInterrupt(1, RemoteEvent, RISING);
StopGates();
// loop:
void loop() {
// current acquisition every 10ms:
if( (millis()-timeCurrent)>=10 ) {
timeCurrent = millis(); // reinit current chrono
I1array[ImesCount] = analogRead(PIN_CURRENT_M1);
I2array[ImesCount] = analogRead(PIN_CURRENT_M2);
ImesCount++;
if(ImesCount >= 10) {
ImesCount = 0;
// median filter
isort(I1array, IMESARRAY_SIZE);
modeM1 = mode(I1array, IMESARRAY_SIZE);
currentM1_inAmp = (float)(modeM1)*5.0f/1024.0; // 1024 <-> 5V=5A
isort(I2array, IMESARRAY_SIZE);
modeM2 = mode(I2array, IMESARRAY_SIZE);
currentM2_inAmp = (float)(modeM2)*5.0f/1024.0; // 1024 <-> 5V=5A
// read buttons:
boolean bStop = false/*digitalRead(PIN_BP_STOP)*/;
boolean bOpen = false/*digitalRead(PIN_BP_OPEN)*/;
boolean bClose = false/*digitalRead(PIN_BP_CLOSE)*/;
#ifdef _DEBUG_BP
// debug:
unsigned long static waitalittle;
if(millis()-waitalittle > 500) {
waitalittle = millis();
Serial.print("bStopNow:"); Serial.print(bStopNow); Serial.print("; bOpening:"); Serial.print(bOpening); Serial.print("; bClosing:"); Serial.println(bClosing);
#endif // _DEBUG_DP
// TODO: debounce buttons
// remote control read:
if(newState != currentState) { // remote control detection
switch(newState) {
case STATE_STOP1:
case STATE_STOP2:
bStop = true;
bStopNow = true;
break;
case STATE_OPEN:
bOpening = true;
nextState = INIT_OPEN;
break;
case STATE_CLOSE:
bClosing = true;
nextState = INIT_CLOSE;
break;
default: bStopNow = true;
currentState = newState;
Serial.print("current state:"); Serial.println(currentState);
Serial.print("bOpen:"); Serial.print(bOpen); Serial.print("; bClose:");Serial.println(bClose);
Serial.print("bStopNow:"); Serial.print(bStopNow); Serial.print("; bOpening:"); Serial.print(bOpening); Serial.print("; bClosing:"); Serial.println(bClosing); Serial.println("");
// set flag for state machines
if(bOpen && !bStopNow && !bOpening && !bClosing) {
bOpening = true; // flag to start opening process
newState = STATE_OPEN;
else if(bClose && !bStopNow && !bClosing && !bOpening) {
bClosing = true; // flag to start closing process
newState = STATE_CLOSE;
// state machines
if(!bStopNow ) { // until a stop condition appears
if(bOpening) {
nextState = fsmOpen(nextState);
if(nextState == END_OPEN) {
StopGates(); // stop
bOpening = false; // end of opening process state machine
newState = STATE_STOP2;
SendMessage("End of opening process.");
else if(bClosing) {
nextState = fsmClose(nextState);
if(nextState == END_CLOSE) {
bClosing = false; // end of opening process state machine
SendMessage("End of closing process.");
else {
StopGates();
if(bStopNow) { // press "open" or "close" button to release the "stop" state
StopGates();
bStopNow = false;
bOpening = false;
bClosing = false;
if(currentState == STATE_OPEN) { newState = STATE_STOP2; }
else if (currentState == STATE_CLOSE) { newState = STATE_STOP1; }
else { newState = currentState; }
SendMessage("StopEvent");
Serial.print("Stop count: "); Serial.println(StopCount); Serial.println("");
void StopGates() {
// stop the gates
isM1Stopped = true;
isM2Stopped = true;
ResetFlashLight();
SendMessage("stop");
void StopGateM1() {
// stop the gate M1
isM1Stopped = true;
SendMessage("stop M1");
void StopGateM2() {
// stop the gate M2
isM2Stopped = true;
SendMessage("stop M2");
void OpenGateM1() {
// open gate motor M1
digitalWrite(PIN_RELAY_M1A, HIGH);
SendMessage("opening 1st gate...");
void OpenGateM2() {
// open gate motor M2s
digitalWrite(PIN_RELAY_M2A, HIGH);
SendMessage("opening 2nd gate...");
void CloseGateM1() {
// close gate motor M1
digitalWrite(PIN_RELAY_M1B, HIGH);
SendMessage("closing 1st gate...");
void CloseGateM2() {
// close gate motor M2
digitalWrite(PIN_RELAY_M2B, HIGH);
SendMessage("closing 2nd gate...");
void SendMessage(char *Message) {
Serial.println(Message);
void StopEvent() {
StopCount++;
bStopNow = true; // memorize "stop" button
void RemoteEvent() {
switch(currentState) {
case STATE_STOP1: newState = STATE_OPEN; break; // from stop to open
case STATE_OPEN: newState = STATE_STOP2; break; // from open to stop
case STATE_STOP2: newState = STATE_CLOSE; break; // from stop to close
case STATE_CLOSE: newState = STATE_STOP1; break; // from close to stop
default: newState = STATE_STOP1;
// SendMessage("Remote Control event.\r\n");
unsigned char fsmOpen(unsigned char state) {
unsigned char returnState = END_OPEN; // default
// check overcurrent at every iteration to stop gate in case of obstacle
// M1 overcurrent test:
if( (state > OPEN_M1) && ( (millis()-timeStartOpenM1) >= TIME_INHIBIT_IMES_INMILLISEC && (isM1Stopped == false) ) ) { //1s inhibit current measure
if(currentM1_inAmp > MAX_OVERCURRENT_IN_AMP) {
char msg[40];
int n = sprintf(msg, "M1 overcurrent detect: ");
dtostrf(currentM1_inAmp, 3, 1, msg+n);
SendMessage(msg);
StopGateM1(); // halt M1
else if(currentM1_inAmp < MIN_MOTOR_CURRENT_IN_AMP && (isM1Stopped == false) ) {
// no current detection : maybe a sensor failure => STOP
SendMessage("No M1 current value!");
// M2 overcurrent test:
if( (state > OPEN_M2 ) && ( (millis()-timeStartOpenM2) >= TIME_INHIBIT_IMES_INMILLISEC && (isM2Stopped == false) ) ) { //1s inhibit current measure
if(currentM2_inAmp > MAX_OVERCURRENT_IN_AMP) {
char msg[40];
int n = sprintf(msg, "M2 overcurrent detect: ");
dtostrf(currentM2_inAmp, 3, 1, msg+n);
SendMessage(msg);
StopGateM2(); // halt M2
else if(currentM2_inAmp < MIN_MOTOR_CURRENT_IN_AMP && (isM2Stopped == false) ) {
SendMessage("No M2 current value!");
// stop if needed:
if(state == END_OPEN) {
StopGates();
return END_OPEN; // exit fsm
switch(state) {
case INIT_OPEN:
SendMessage("Start Opening process...");
lastTimeCheck = millis();
SetFlashLight();
returnState = OPEN_M1; // next state
break;
case OPEN_M1:
timeStartOpenM1 = millis(); // memorize date for opening M1
OpenGateM1(); // open first gate
returnState = OPEN_DELAY; // next state
break;
case OPEN_DELAY:
if( (millis() - timeStartOpenM1) >= DELAYINMILLISEC ) {
returnState = OPEN_M2; // next state
else {
returnState = OPEN_DELAY; // stay in delay
break;
case OPEN_M2:
OpenGateM2();
timeStartOpenM2 = millis(); // memorize date for opening M2
returnState = WAIT_OPEN_END;
break;
case WAIT_OPEN_END:
if( (millis() - timeStartOpenM1) >= TIMEOUTMOTORINMILLISEC ) { // time elapsed since M1 start
returnState = END_OPEN; // next state
else {
if(isM1Stopped && isM2Stopped) { // both motors are stopped, np need to wait more
else {
returnState = WAIT_OPEN_END; // stay in delay
break;
case END_OPEN:
StopGates();
break;
default:
StopGates(); // stop when default
if( (millis()-lastTimeCheck) >= 1000 )
Serial.print("Opening time: "); Serial.print( (millis()-timeStartOpenM1)/1000 ); // time since the begining of the opening fsm
Serial.print("; Current M1 = "); Serial.print(currentM1_inAmp); Serial.print("\tCurrent M2 = "); Serial.println(currentM2_inAmp);
return returnState;
unsigned char fsmClose(unsigned char state) {
unsigned char returnState = END_CLOSE;
if( (state > CLOSE_M2 ) && ( (millis()-timeStartCloseM2) >= TIME_INHIBIT_IMES_INMILLISEC && (isM2Stopped == false) ) ) { //1s inhibit current measure
char msg[40];
SendMessage(msg);
StopGateM2(); // halt motor
if( (state > CLOSE_M1 ) && ( (millis()-timeStartCloseM1) >= TIME_INHIBIT_IMES_INMILLISEC && (isM1Stopped == false) ) ) { //1s inhibit current measure
char msg[40];
SendMessage(msg);
StopGateM1(); // halt motors
// stop if needed:
if(state == END_CLOSE) {
StopGates();
return END_CLOSE; // exit fsm
switch(state) {
case INIT_CLOSE:
SendMessage("Start Closing process...");
SetFlashLight();
returnState = CLOSE_M2; // next state
break;
case CLOSE_M2:
timeStartCloseM2 = millis(); // memorize date for closing M2
CloseGateM2(); // close first gate
returnState = CLOSE_DELAY; // next state
break;
case CLOSE_DELAY:
if( (millis() - timeStartCloseM2) >= DELAYINMILLISEC/*-3000*/ ) { // TODO: -3000 for debug: erase it quickly!
returnState = CLOSE_M1; // next state
else {
returnState = CLOSE_DELAY; // stay in delay
break;
case CLOSE_M1:
CloseGateM1();
returnState = WAIT_CLOSE_END;
break;
case WAIT_CLOSE_END:
if( (millis() - timeStartCloseM2) >= TIMEOUTMOTORINMILLISEC ) {
returnState = END_CLOSE; // next state
else {
return END_CLOSE;
else {
returnState = WAIT_CLOSE_END; // stay in delay
break;
case END_CLOSE:
StopGates();
break;
default:
Serial.print("Closing time: "); Serial.print( (millis()-timeStartCloseM2)/1000 ); // time since the begining of the closing fsm
return returnState;
void isort(int *a, int n)
//Sorting function
// sort function (Author: Bill Gentles, Nov. 12, 2010)
// *a is an array pointer function
for (int i = 1; i < n; ++i) {
int j = a[i]; int k;
for (k = i - 1; (k >= 0) && (j < a[k]); k--) {
a[k + 1] = a[k];
a[k + 1] = j;
int mode(int *x,int n){
//Mode function, returning the mode or median.
int i = 0;
int count = 0;
int maxCount = 0;
int mode = 0;
int bimodal;
int prevCount = 0;
while(prevCount&count>maxCount){
mode=x[i];
maxCount=count;
bimodal=0;
if(count==0){
i++;
if(count==maxCount){//If the dataset has 2 or more modes.
bimodal=1;
if(mode==0||bimodal==1){//Return the median if there is no mode.
mode=x[(n/2)];
return mode;
void SetFlashLight() {
timeStartFlashLight = millis(); // start flash light
FlashLightState = true;
digitalWrite(PIN_FLASHLIGHT, HIGH);
SendMessage("Flashlight ON");
void ResetFlashLight() {
SendMessage("Flashlight OFF");
(It's not very easy to read because of the state machines.)
Hi Manu
could you implement multi button RC
My project is essentially breadboard-based, so I don't have any schematic to post. I will try to find my old hand drawn schematic and scan it...
Hi Manu
could you please share the schematic
Hi Manu
Hello, I tried with a humble opamp and it's not very satisfying. So, why not a dedicated current sensor chip. What type are you thinking about : INA210, ACS714, or something else?
Even though I haven't tried it yet, anything that looks like a differential amplifier would be better because when the second motor starts, the shunt resistors "see" a part of the current of the other motor. Not sure what is going on, but I may be good to improve that.
Hi Manu
Its quite interesting !
Can we use current sensor chip to detect the peak and use it for limit as well as
for protection ?
