I happen to have a number of small low-power speakers "in stock". From Left to Right:
- 5 Pcs Internal Speakers Magnet 30x20mm 2500Hz 8Ohm 1W for PC Laptop (affiliate link, you might be able to find a better price)
- 8 Pieces 28mm 8Ohm 8Ω 1W Internal Magnetic Round Audio Speaker Loudspeaker BE (affiliate link)
- 1PC/2PC/4PC 28mm 8Ohm 8Ω 2W Audio Speaker Stereo Woofer Loudspeaker Trumpet Horn (affiliate link)
I connected a couple of them up directly to the "line out" connections - it was barely audible. An amp will be needed... in the next post.
