1Step 1
Open up your editing window by adding a project log or instructions etc.
2Step 2
Write your post, either until you get to the point you want to add
strikethroughtext or the whole thing.We can do all the
strikethroughat the end. -
3Step 3
Now click the <> button at the top of your editing box. If your draft post disappears, don't worry (yet) - scroll up to see if it has been turned into plain text at the top.
Disclaimer - I use imgur to link my images in, so I don't know what effect this has on other methods of inserting images
4Step 4
find the text you want to
strikethroughand before it type:
<del>
and after it type
</del>
5Step 5
Then repeat for any other sections you may want in
strikethrough. When you have finished, press the <> button again and your nicely formatted post should reappear.Good luck.
Simon Merrett
