1Step 1
Because those guys from the "shack-standard power plugs" that you can find on hackaday are also working in shackspace, the Stuttgart hackerspace, we used their system for our first mobile ground station.
it is pretty easy and if you buy those components from the list and link them as seen here, you will do it right.
2Step 2
if you stick to the color code of black being - and red being +, you will connect it correctly.
hornig
