The progress of donations is going well and we reached 71% of the goal.
A big thanks to all donors!
New Version of Electrical Schematics
We just received a new version of the schematics (v0.5) that raise the power consumption footprint up to 90W in order to support higher end MXM 3 video cards that may reach a maximum of 55W under heavy load. As an example, the AMD Radeon E9174 (GCN 4.0) has a TDP of 50W.
We will publish in our repository this new version of the schematics ( pdf format and Orcad source) as soon as we finish an internal round of checks in close collaboration with ACube Systems, as we would like to ensure that it can be considered finalized.
PCB Design Timeline
In the next few days the engineer taking care of the motherboard design will concentrate on the PCB, as the Electrical Schematics are now stable enough.
Thanks to the donations already received, the work on the PCB design ( done with Mentor pads ) can move forward and we estimate it could be completed by September 2020. The timing is somehow unfortunate, as August in Italy is a month where anybody is on holiday, nevertheless, we will do our best to avoid interruptions.The date of publication of the PCB design will depend on the results of the internal review process once we receive it, hopefully it will not take long. The design of the PCB fit inside the Slimbook Eclipse body.
We will export the Orca electrical schematic design even to EDIF format, to make easier for new volunteers to convert it to Kicad Format. To convert from EDIF to Kicad we have found edif2kicad tools https://github.com/svn2github/edif2kicad but we are sure you will find other tools or even you will be able to create a new one
In case you are able to convert our PCB Mentor Pads design to Kicad you are welcome to do it. If you have any issue when doing so, contact us and we will be happy to provide some help.
More time for Donations
After an internal discussion, we decided to postpone the deadline of the current Donation Campaign (Phase 1A) to the 30th of July 2020.
The plan is to deliver the PCB design with the end of Phase 1A, and right after that start Phase 1B “Fast SI bus simulations” on the 1st of August with a goal of €5000 (around $5600). As a consequence, there will be no interruption in the donation campaign, it will transparently fade from Phase 1A to Phase 1B seamlessly.
We kindly ask all followers, friends, and donors to concentrate their donations before the 30th July 2020, to ensure the end of Phase 1A without further delays.
We also kindly invite any of you that is capable of technically reviewing the hardware schematics to contact us, as that will help speed up the design process, as well as improving the overall quality of the final motherboard.
You can now donate from any country thanks to Stripe Payment Gateway
Potential donors from Countries such as Lebanon and China were unable or had serious difficulties to donate via Bank transfer and PayPal. The issue is now solved thanks to the addition of Stripe Gateway among the payment methods, they applied for us a discounted rate being a non-profit organization and they charge a commission on each donation of 1,2%+0,25€ inside the EU, and 2,9%+0,25€ outside the EU.
Donation Campaign for PCB design of the PowerPC Notebook motherboard
