We are happy to share to all the donors and followers the Board Layout of our PPC64 Notebook Motherboard!!!
The design of our board layout is meant to fit inside the Slimbook Eclipse body. The PCB Design which is currently being worked on using Mentor Xpedition.
In September 2020 we have published on our gitlab repository the Orcad source file with the latest version (v0.6) of the Electrical Schematics, you can go more deep on these board layout starting from the Orcad source.
Open Hardware PowerPC Notebook Board Layout for Slimbook Eclipse Body – TOP
Open Hardware PowerPC Notebook Board Layout for Slimbook Eclipse Body – BOTTOM
The tentative deadline for Phase1B is 2th November so there are two weeks left to donate the remaining 3660 euros. If we will reach the goal, the PCB with SI bus simulation should be ready by the end of November.
In this case in December 2020 we will work on production of the Prototypes together with the Prototypes Donation Campaign.
We have to give a name to the motherboard, suggestions still remain open few days more on our forum
