Thanks to the kind contribution of the donors, we just reached the goal of the campaign for financing Phase 1B “Fast simulation bus”.
The PCB (Printed Circuit Board) design is currently being finalized, as soon as we have reviewed it, we will publish it in our GitLab repository. This last phase was of fundamental importance as we could test the correctness of the design, paving the way for the next campaign.
We got through the hardest parts with regards to the Research and Development choices. We past the uncertain ground with its many open challenges and many solutions have been explored. We also past the economical goal of previous campaigns that were quite heavy, and thanks to many people we have managed to get this far, again, thank you all!
We are now ready to launch Phase 2 “Production and delivery of five working prototypes” with a goal of 10500 Euros (around 12720 USD).
Donation Campaign for Production of five working Prototypes
Our target is to complete this new campaign by Spring 2021, and we are working again with the patient guys at ACube Systems that will assist us in making the five prototypes.
These prototypes will be very important as they will be used to
- put the PCB design to the test
- learn how to correctly initialize the hardware
- fine-tune the configuration of U-Boot
- fit the motherboard in the Eclipse Slimbook body
So far, we worked with U-Boot on the NXP T2080 RDB Devkit but that is quite different to our motherboard, which is quite more complex. We have to fine-tune U-Boot directly on the final hardware, and the prototypes will be essential for this. In addition, work on U-Uoot is still required even with the Devkit in order to correctly set up the framebuffer. Right now we can access the U-Boot console in serial mode only. ACube Systems will assist us on this task.
The motherboard is designed (screw and ports positions) to fit inside the Eclipse Notebook body that the prototypes should be mounted on.
Moreover, we need to redesign the dissipation heat pipes that will be slightly different from what was originally in place for the Eclipse Notebook.
Maybe some of you didn’t even think it was possible but we are progressing. The journey is still not finished. We need you to tell about this project all around you as we need more interested people, more donations.
2021 is our year! Let’s make this project a reality!
Roberto Innocenti
