Schematics of the Powerboard Tyche Desktop version Completed! Soon starting the PCB design
A project log for OSHW GNU/Linux PowerPC Notebook
Open Source Hardware GNU/Linux PowerPC Notebook project
roberto-innocentiRoberto Innocenti 10/30/2025 at 23:170 Comments
We now have the complete electronic source design for our new desktop design in our hands!
This week, ACube Systems and some volunteers from our association will review the design. We expect the manufacturer to start setting up the PCB layout for the new Powerboard Tyche Desktop on October 20th. This is part of our strategy to focus on creating a stable, functional desktop version of the core computing platform by the end of 2025.
The PCB design phase (Phase 2) will begin shortly after the schematics and Bill of Materials (BOM) are sent to the manufacturer. We anticipate that this step will allow the manufacturer to provide us with an estimate of the cost and timeline for the PCB layout design. This cost and timing estimate will then be shared with the community “just in time.”
Technical Components and NXP Review
We have verified that the availability of SATA2/3 controllers is poor, and the chip Lattice Silicon Image SiI3132 chip that we selected is no exception. We decided to include it in our desktop board to ensure backward compatibility with SATA devices, such as DVD and HDD.
We do not use the on-chip T2080 SATA2 controller because we prefer to use the T2080’s three x4 PCIe Gen3 configuration to optimize the speed of video cards and storage controllers. This configuration cannot coexist with the on-chip SATA2. In any case, the best performance is possible thanks to our M2 motherboard interfaces.
In our board design, we have an SPI connection for an external LCD, which can be used as a secondary screen or for debugging and diagnostics. It is also useful when setting up u-boot and when no video card is connected to the board.
Our board design includes GPIO connectors that can be used to connect other devices that don’t use USB, SPI, or PCIe buses.
Our desktop design is derived from our old notebook design and the original NXP T2080 RDB (Release F) design. We are integrating many components specified in the reference board, including critical monitoring hardware.
This includes the OnSemi ADT7481ARMZ thermal monitor, which has been upgraded to the OnSemi NCT72. The ADT7481 is used as the thermal monitor or temperature sensor on the original NXP T2080 reference design board. On that board, the ADT7481 (designated U34) is usually connected via the I2C_1 bus with the address 0x40. The T2080 processor itself contains a temperature diode designed to be used with system temperature monitoring devices, such as the Analog Devices ADT7461A. This similar part is mentioned in the documentation for the T1042 chip, which highlights the standard use of such monitoring.
Designers have changed other components from the original T2080 RDB design and our notebook design due to the availability of new compatible models, such as the N25Q512A13 FLASH SPI, which is substituted for the EvKit Micron MT25QL512A due to its limited availability.
Due to the changes in components, we will need to modify the VHDL code of the CPLD chip when we have the prototypes in our hands. Therefore, we must take into account the additional cost of this task.
To ensure full compliance and open-source publication readiness,
  • The designer will fill out the NXP review questionnaire [draft post 2025-10-12] simultaneously.
  • The questionnaire and the Cadence schematic source will then be sent to NXP.
  • The main goal is to receive a full or partial agreement to publish the parts of our design derived from the original NXP T2080 RDB (Release F) as open hardware
  • We anticipate a robust boot-up because the components and firmware are similar to those of the stable T2080 RDB. The specific CPLD is programmed using the original CPLD source code of the T2080 RDB. Once NXP grants the necessary agreement, we plan to publish the source schematics and evaluate the use of a recent CERN Open Hardware License version.
    Upcoming Project Phases
    The next anticipated milestones, pending finalization of cost estimation:
    We continue to rely on the community’s support. Recurring donations are dedicated to the campaign aimed at recovering costs already incurred for notebook testing and CPLD firmware fixin
    We are searching volunteers to test Debian PPC64 and fix packages
    Finally, we need more volunteers to support the necessary software efforts, including Debian PPC64 testing, as we cannot ask for additional donations for this purpose.
    Below is an updated list of specs for the desktop board being designed.
    Form Facttor: Micro ATX
    CPU: NXP T2080, e6500 64-bit Power Architecture with Altivec technology
        4 x e6500 dual-threaded cores, low-latency backside 2MB L2 cache, 16GFLOPS x core
    RAM: 2 x DDR3 Slots
    VIDEO
        PCIE3 x16 VIDEO Card 1
        PCIE2 x16 VIDEO Card 2
    AUDIO: C-Media 8828 sound chip, audio IN and audio OUT jacks (3x2)
    USB:  2 USB 3.0 ports
          2 USB 2.0 ports
          2 USB 3.0 ports internal for FRONT
    STORAGE:
        2 NVM Express (NVMe)
        2 x SATA2
        1 x SDHC card reader
    NETWORK:
        2 x Gigabit ethernet RJ-45 connecto
    More info
