74HC_HCT253.pdf
Datasheet for the 74HC252, a dual MUX4 with tristate output
Adobe Portable Document Format - 748.92 kB - 06/14/2017 at 22:29
Preview
74HC182.pdf
Datasheet for the 4-inputs carry lookahead generator in CMOS
Adobe Portable Document Format - 213.02 kB - 06/14/2017 at 21:24
Preview
mm74hc259-303675.pdf
Datasheet for the 8 bits addressable latch (8×1 SRAM)
Adobe Portable Document Format - 76.87 kB - 06/14/2017 at 20:36
Preview
MC74HC181B1.pdf
Datasheet for the famous 4-bits ALU, in narrow DIP and CMOS version (you can touch it with your fingers without risks of burns !)
Adobe Portable Document Format - 216.98 kB - 06/14/2017 at 20:34
Preview
mm74hc251.pdf
Datasheet for the 8-to-1 multiplexer with tristate output.
Adobe Portable Document Format - 74.80 kB - 06/14/2017 at 20:34
Preview
