Printable StickVise v4.stl
STL generated from defaults, should be compatible with standard StickVise Dimensions, now has jaws built in.
Standard Tesselated Geometry -
678.59 kB -
06/13/2017 at 07:49
Download
Printable StickVise v4.scad
Jaws are now printable also! No need to rely on the external generator, simplified some parts into inches with a function, fixed a spacing bug that showed up for the taller pieces.
scad -
5.27 kB -
06/13/2017 at 07:46
Download
Printable StickVise v3.stl
STL generated from defaults, should be compatible with standard StickVise Dimensions.
1.08 MB -
06/11/2017 at 00:15
Download
Printable StickVise v3.scad
Parts rotated to a more printer-friendly orientation, largest bore holes facing upwards to reduce overhangs. Added Extra parameters for spring tensioner
scad -
4.54 kB -
06/11/2017 at 00:01
Download
Printable StickVise v2.stl
1.02 MB -
06/10/2017 at 07:13
Download
Printable StickVise v2.scad
Fully parametric OpenSCAD, make it as big or small as you'd like, change shaft diameters, screw sizes, anything really.
scad -
3.73 kB -
06/10/2017 at 07:10
Download
Printable StickVise.scad
First iteration for proof of concept.
scad -
2.88 kB -
06/11/2017 at 00:02
Download
