Cut of the original POT/Switch from the original board, Isolated the connections and wired it to the Arduino using the switch part to select the mode and the pot to adjust the speed.
To select / change the mode of operation you turn the switch on and off, when the unit starts it is in mode 0, turn the switch on and it jumps to mode 1 (simple vibrate)
Turn it Off then ON and it goes to Mode 2 ( Pulsate, ramps the motor up to the speed set by the pot then drops to zero)
On and Off again selects Pulsate or mode 3 (Speed climbs up, then back down to the setting on the pot)
On and Off again goes back to Mode 0, everything off.
