1Step 1
Pretty simple, Gut the original wand and remove the controller, motor etc.
2Step 2
Grind a flat/key on the shaft of the BLDC motor to slip in to the vibrator connector.
3Step 3
Machine up a holder that allows the BLDC motor to fit in where the old motor came from
4Step 4
Wire the BLDC up to the ESC and the EXC to the arduino
5Step 5
Modify the Pot/Switch and connect that to the arduino
6Step 6
Flash the ardunio with some simple code and Happy Teeth Rattling.
7Step 7
In this one I had to tweak the speeds down and run the motor at about 1/4 of full speed, apparently there is such a thing as too much vibration.
Boris van Galvin
