Slave Controller for Dual Head Assembly
A project log for Hot Hot (Yushengtech) SMT50 OpenPnP conversion
Refactoring the SMT50 to work with OpenPnP
darrylnDarryl.N 09/07/2019 at 19:090 Comments
Since the placement head has 3 relatively low-power steppers, an LED illuminator, limit switches, etc etc, I am looking at using a slave controller.  The smoothieboard can support it over I2C or SPI (would prefer UART, but that doesn't seem to be an option).  OpenPnP supports  it using a sub-driver.
The slave controller would support
I ordered a 3-channel RAMPS/GRBL board with an Arduino nano for about $20.   Looks like it could be mounted on the back side of the head assembly, and would not add much weight. Firmware is GRBL. so able to customize as required.  There are about 12 I/Os available in addition to the 3 motors and 2 Z limits, so a small perfboard can be added with MOSFETs signal conditioning, etc.
