The software is updated to remove the need to fetch the sunset time from sunrise-sunset.org. This means that the software will continue to run for years in the future, even if this API is removed.
The software now reads a file (sunset.txt) to find the sunset time for each day. The current date/time is fetched from google.com. Let's hope that google.com will still exist in years to come!
