I have been flooded with requests for different variants of this project. Some people want to follow a sunrise/sunset schedule. Some want to turn the lamp off in the middle of the night. Some want a different type of schedule completely.
To answer all of these requirements, I have moved away from the idea of following sunset and sunrise. Now I have only the concept of turning the lamp on once per day and turning the lamp off once per day.
To do this, I have defined a file (lamptimes.txt) which lists the daily on-time and off-time, for example
14 Mar 1837 0651 15 Mar 1839 0648 16 Mar 1840 0646
This means that the user can define any type of desired schedule, as long as it is only required once per day.
Next step is to tackle the hardware. Shouldn't be too difficult !!!
