16 player JS Joust and a ton of other features all running on a Raspberry Pi.
Recently there may have been some crashes when running games with 10+ players. Recently a stability update was added which should allow 18+ players to play Joustmania reliably without it crashing.
A whole range of updates have been added to Joustmania. USB soundcard is no longer required. Mp3, flac, ogg and other sound types are now supported, lots of other improvements and enhancements to gameplay, functionality, and the webui!
Download and Install Raspian on the micro SD card
Connect the bluetooth adapters
Turn on the pi, open a Terminal and run these commands, the pi will reboot on a successful install
git clone https://github.com/adangert/JoustMania.git
cd JoustMania
sudo ./setup.sh
If you have the bluetooth adapters, disable the on-board bluetooth
sudo ./disable_internal_bluetooth.sh
You can now disconnect the hdmi cable and run JoustMania in headless mode. JoustMania will automatically boot up on restart.
