1Step 1
Download and Install Raspian on the micro SD card
Connect the bluetooth adapters
Turn on the pi, open a Terminal and run these commands, the pi will reboot on a successful install
git clone https://github.com/adangert/JoustMania.git cd JoustMania sudo ./setup.shIf you have the bluetooth adapters, disable the on-board bluetooth
sudo ./disable_internal_bluetooth.shYou can now disconnect the hdmi cable and run JoustMania in headless mode. JoustMania will automatically boot up on restart.
Aaron Angert
