Rev 3 arrived from Oshpark, and most of the hardware issues are fixed.
I've had so many comments on how to cut some of the weight- thank you!
From your suggestions, I've removed the PCB under the antenna, saving a couple of grams. Great idea!
I've chosen to keep the battery charging on the PCB. In the final piece, there will be a lot of fast changes and I hate swapping batteries while *doing*other*stuff*. Those tiny battery connectors are a total PITA. A really good idea, but no :)
PCB changes in this rev:
- ESP footprint fix
- New micro USB part with legs that grab into the PCB (thanks to @Voja Antonic for this hint)
- Larger diode that I can see the cathode end (picked one that is way too large, it's in the top left next to label C1 :)
- Battery off switch, which is the wrong part
- PCB cutout under antenna
Net: 19.1 grams with everything on the board is exactly 3 grams too heavy. I think this is OK, the programming header won't need to be there in the final (-1.2 grams) and there will likely be some other reduction.
Changes for next rev:
- New ESP (ESP-M2 or ESP8285)
- Pogo pin fixture
- Slide switch for battery OFF
- Capacitor footprints should be the same (nitpicking)
- Silk screen on back for 3rd motor placement
- 0.8 mm PCB from @oshpark
Immediate next steps are getting the communications going. I'm following this most excellent tutorial here.
@davedarko the PSF-B85 (and the A-85) have the antenna on-board. I have made my own board from scratch using an ESP8285. I used a chip antenna and was careful about the trace design and it works fine. If I look at some of the commercial boards, they don't seem so careful, but they still work fine!
I think I will use a module rather than laying out my own antenna. 😀
I still can't understand why you are using the huge and heavy ESP-12 module, when there are modules like the ESP-03 which are much lighter and smaller.
I'll probably change to the ESP8285 on the next rev
[Left for readibility but based on brainfart]
I like that idea, but there's less support out there
Recommend this ESP8285 module https://www.itead.cc/wiki/PSF-B85
@davedarko Why do you say there is less support out there? It works just like an ESP8266
@Paul Andrews wuah, sorry I was confusing the ESP8285 with the ESP14 module that has an STM8 on it. Nevermind, sure ESP8285 makes sense, good luck with the antenna design!
Thanks Dave! Someone on twitter recommended making a pogo pin fixture for programming. Swiss cheese...maybe, I think that might interfere with the aerodynamics (haha, as if a balloon could be described as aerodynamic)
hehe :) thought so too with the aerodynamics ... you never now, maybe it vibrates and whistles with too many holes :D pogo pin stuff sounds good too :)
there are locking header footprints, where every second pin is offset a bit. With that you can put in a header when needed and it wont fall out.
You could take a bigger drill to make it a bit more swiss cheese like / voronoi style.
Looking forward to see a blimp fly :)
Me too, me too 😀 really wish there was a blimp emoji
