Verilog Uploaded to Github
A project log for NTSC Shield
NTSC Shield for Mojo V3
ryanRyan • 06/24/2017 at 02:05•0 Comments
The working Verilog code for the NTSC Shield is available on Github. There are two branches:
Current working progress is to integrate the SRAM test results to the television, which will run on startup.
