In the beginning God created the heaven and the earth. And human beings. And human beings created digital kitchen timers, like this one.
And human beings said, Cool but a little dismal. Let's make a better one!
And God said, I heard your call, let there be Arduinos: and there was Arduinos all over the earth, and that was good.
And human beings took an Arduino and created a better kitchen timer, like this one.
Hardware components:
Arduino UNO & Genuino UNO *1
Adafruit Standard LCD - 16x2 White on Blue *1
SparkFun Pushbutton switch 12mm *4
Single Turn Potentiometer- 100k ohms *1
Buzzer *!
And God saw the new kitchen timer and said: I saw your new kitchen timer and it looks awful, but it seems too much fun! And that is good. :-)
What you need to have
Now that you know where all this came from, let's go deep into it.
All components I used came from the Arduino Starter Kit, including the small breadboard you see in the pics and in the video. Feel free to accomodate the project into a larger one, if you wish.
You'll need a power source too: while playing around, the PC' USB port and cable will be enough.
What you need to do
First: please gather all needed components from the Starter Kit or your preferred component bin; if you don't have one, don't panic. There's plenty of on the Internet. You can find the component list below.
And, well, you'll need the code too. It's in its box, below again.
How it works
Basically, like any other similar device you can buy for a buck at any store near you. But this is yours. And this will show you how those little gadgets actually work.
The keyword here is: current mode. The timer itself can run in only one out of four modes at a time:
IDLE - the timer is awaiting for your input, showing the currently set time amount; this is also the initial mode after power up or reset.
SETUP - you can enter this mode by long-pressing S4 (in the code this is called also "reset button"); here, by using S3 ("start stop button"), you can choose which value to change in order to set the elapsed time to be counted down later; finally, using S2 ("down button") and S1 ("up button") respectively, you can decrease or increase the choosen value (hours, minutes or seconds).
RUNNING - You can enter this mode by pressing S3, while leaving it will require both S3 or S4 (which will lead you to IDLE mode).
RINGING - When the desider amount of time is elapsed, this mode is automatically activated; you can leave it (i.e., make the little boy stop ringing) by pressing any switch.
The code
First, we need to include the proper libraries:
#include <LiquidCrystal.h>
#include <Time.h>
If you don't have them already, you'll need to download and install them:
Next, let's initialize that nice LCD module:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Please feel free to scramble the pins at your will in order to obtain a nice wiring layout: don't follow me in this, as I did a terrible wiring plan! :D For instance, you can reverse the latter four pins in the above statement in order to avoid the yellow wires crossing you can see in the schematic below (obviously, you'll have to adjust the button pin constants accordingly, see below). Play, have fun! The life with Arduinos starts right after that copy/paste!
The next 51 code lines contain the static variables declaration and initialization. Please feel free to browse them, their crystal-clear names and some scattered comments will guide you understanding the whole thing.
The setup() function carries out the usual preliminary steps you've seen gazillions of times in any Arduino sketch out there and so far. The only notable statement is the first, which will set the initial LCD display cursor's position. Because, yes: this module requires you to setup a position along its rows and cols and then to "print" something, which will appear starting from that position.
Now let's move to the loop() function....
Connect the 7-segment LED display, pushbuttons, and piezo buzzer to the Arduino according to the circuit diagram.
Upload the Arduino code to the Arduino.Test the timer by pressing the start button and the reset button. The timer should count down from 60 seconds and sound a buzzer when the time is up. The Government of Pakistan has opened the Registration Window for Ehsaas Program 2022-23, and interested individuals can apply for Several Categories of the Ehsaas Program using SMS or Web-portal services.
