Check out the following ST video for a novel technique to remove the need to calibrate the VL53L1x sensor on the MappyDot for crosstalk if you are using a glass cover:
Nice presentation by ST there. I plan to use VL53L1X as the primary proximity sensor on #EXPLOG : Exploration Logger . There'll be a glass cover on top. I think this technique would help mitigate any cross-talk issues.
Interesting. :-)
Waveguides are as much an art as a science...
