First MappyDot Working
A project log for MappyDot
Micro Smart LiDAR Sensor
blair-wyattBlair Wyatt • 07/16/2017 at 08:12•0 Comments
The first MappyDot has been programmed and is operational:
You can see the infrared beam coming from the VL53L0X sensor as it takes it measurements.
The following demo shows the LED lighting up after it reaches a threshold value (200mm):
And for fun:
