Development Board
A project log for MappyDot
Micro Smart LiDAR Sensor
blair-wyattBlair Wyatt • 08/05/2017 at 05:06•0 Comments
I have created a breakout development board for the MappyDot to help people develop different applications. It brings out the ISP programming headers and has a reset button, master select jumper, optional I2C resistors and mounting holes. This is an easier to use alternative for development, than just creating an adapter for the ISP pins.
The dev board gives you the option to either connect headers to the MappyDot boards for easy removal, or to solder the MappyDot directly to the board.
The dev board schematic and production files are located on the git repo - https://github.com/MappyDot/Hardware/tree/master/MappyDotDevBoard. Or available here on OSHPark. They will also be available for sale with the MappyDots as a kit with headers.
