Here's a quick gesture recognition demo with multiple MappyDots feeding into a slow and dirty python visualisation script. The MappyDots are also showing that they work when their fields of view overlap as well as a PWM LED output (ignore the differing LED brightness on some of the Dots in the demo, they have different LEDs from different prototype batches). The threshold for the PWM is configurable and currently set to dim at 300mm.
