The physical setup is a modified HERMS setup using an external counterflow heat exchanger instead of an exchanger imersed in the water tank. I expect this modified setup will allow greater efficiency in heat exchange when compared to a traditional HERMS.
Bit sad that you've stopped working on it after the prize ended
