Hackaday.io Hackaday.io
Sign up Log in
Smill
a Large format Milling Machine, self replicable, transportable, and able to cut pieces larger than the machine itself.
enricoenrico
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
636
0
4
4
Team (1)
  • enricoenrico
Join this project's team
  • fab academy page
hardware
ongoing project
CNC fablab transportable diy self replicable opendot
This project was created on 06/22/2017 and last updated 9 years ago.
Description
Right now almost all the CNC machines are bigger than the material they cut. I'd like to make something that does the opposite: a machine smaller than the material that it cuts.
This means that to save space inside a lab: the CNC could be stored in a corner, behind the plywood panels, and put to work only when needed.
A second objective would be to make the machine with simple, cheap consumables and parts that can be fabricated with fablabs machines, possibly with the CNC process to make it self replicable.
Build Instructions
Collapse
  • 1
    Step 1
    how to make SMILL is described here:
    http://fabacademy.org/archives/2015/eu/students/bassi.enrico/project03.html
    at the moment the mechanical solutions are too unstable and the rigidity of the project should be increased, by both changing the materials and the design.
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
Hand machine nerf guns and gatling gun from Iron man 2 movie.
Project Owner Contributor
War Machine Nerf Armor
mike-volckmannMike Volckmann
In this video, we will try to make a simple cnc machine with you. “ A SIMPLE HOMEMADE TRIPLE MACHINE “.
TRIPLE CNC MACHINE
esrarengiz1984esrarengiz1984
Reception, preparation, and use of an XH7115C (VMC210C) CNC machine.
Import CNC machine
austin-macdonaldAustin MacDonald
Fixing up vintage sewing machines for hobby use.
Vintage sewing machines
joseph-eoffJoseph Eoff
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Smill", please tell us the reason.
Send message
Remove Member
