PCB and SCH files
06/23/2017 at 02:13 • 0 commentsThe current version of the ExpressPCB software can be used to open the files.
The Code
06/23/2017 at 00:15 • 0 comments' {$STAMP BS2} ' {$PBASIC 2.5} RCT VAR Word rcreps VAR Byte PDA PIN 7 RadioSwitch PIN 10 HIGH RadioSwitch PAUSE 3000 LOW RadioSwitch rcreps = 0 DO INPUT PDA RCTIME PDA, 1, RCT DEBUG ? RCT PAUSE 500 SELECT RCT CASE = 0 rcreps = rcreps + 1 IF (PDA = 0) THEN rcreps = 0 ELSE IF (rcreps = 3) THEN LOW RadioSwitch rcreps = 0 ENDIF ENDIF CASE = 1 rcreps = rcreps + 1 IF (rcreps = 3) THEN LOW RadioSwitch rcreps = 0 ENDIF CASE ELSE HIGH RadioSwitch rcreps = 0 PAUSE 3000 ENDSELECT DEBUG ? PDA DEBUG ? RadioSwitch LOOP
Apparently highlighting isn't available for Basic. Who would have thought.
This code always worked to switch over to the audio output from the PDA, but would randomly cut the radio out when I wasn't using the PDA.
I never bothered to fix the problem, or figure out why. I was so happy that I had done something electrical that worked I said 'Fuck it, it's good!'
