Diagram of HandyPhone (slightly out of date, FLORA should be Pro Trinket):
The HandyPhone is a covert cellphone that you can wear on your wrist.
This is what the design was going to be before I changed it, for anyone that is interested.
This a slightly out of date image of the layout of the device. I have replaced the flora with a Pro Trinket and moved it from the bottom to the upper enclosure. The mic is also not pictured.
I posted the video at: http://youtu.be/pBmd2crWZ50
I am changing the design of the HandyPhone as suggested by Paul_Beaudet. I will be removing the speaker and replacing it with a Bone Conductor Transducer on the wrist. The mic will also be moved from the pinky finger to the back of the wrist. The phone will no longer be mounted on a glove, but will be completely contained on the wrist.
