Hackaday.io Hackaday.io
Sign up Log in
Resha
A compact portable 3D printer with folding bed and removable toolheads
mo-badrMo Badr
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
30 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
435
1
30
4
Team (1)
  • mo-badrMo Badr
Join this project's team
MISC
ongoing project
3d printer
This project was created on 06/30/2017 and last updated 9 years ago.
Description
I have been working on this idea for a while: a compact portable 3D printer with folding print-bed and quick-detachable print-heads. The aim is to have a portable 3D printer that I can carry around, much like the Ultimaker 2 Go, but small enough to fit in a laptop backpack or a messenger bag. The design I currently have takes about 25x22.5x5.5cm when the bed and spool holder are folded and the print-head removed (the Ultimaker 2 Go is 28x28.7x25.5cm without Bowden tube and spool). The print-head and power supply can be stored inside the printer, only the filament spool will need additional space (for now!).
The print volume is 15x20x17cm, although this requires a slightly more complex mechanism for the y-axis, without it the print volume would be 15x15x17cm. The layer resolution is about 250 to 100 microns. I also have space to add a 12 cell battery, which would theoretically give about two to three hours of printing when using PLA.
Project Logs
Collapse
  • Questionnaire
    Mo Badr • 06/30/2017 at 17:50 • 0 comments
    I would appreciate if you answer the linked questionnaire to let me know if you think this printer is worth buying, at what price, and what features are important?
    https://goo.gl/forms/TRMkjYSkRQtBrpFF3
View project log
Log In/Sign up to comment
Sign up with Github
OR
kelvinA wrote 03/10/2022 at 21:19 • point
This project still ongoing?
Mega kossel delta XXLprinter
Project Owner Contributor
Mega 3d printer
blueflowerBlueFlower
Mostly 3D printed Office printer with a build area the size of an A3 sheet sporting a Diamond 3-colour hotend
(Office 3D Printer) P_3D mk. 1
reniermRenierM
I needed a 3D printer enclosure to keep it warm so it could print ABS. Thais is the first go at it and it looks like it is working well.
Easy 3D printer enclosue
denysdenys
Custom made CoreXY based 3D Printer with Fixed Bed
TitanXY 3D Printer
adamfilipadamfilip
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Resha", please tell us the reason.
Send message
Remove Member
