Too Many Inductors
07/06/2017 at 00:18 • 0 commentsThe first test used an inductor per LED segment. This works, but would be bulky and expensive for larger displays. I simulated using P-channel MOSFETs to switch the LEDs using a common boost inductor:
The LEDs and specific MOSFETs in the circuit were just conveniently in the LTspice library - I have no idea if they are actually suited to this application (I didn't check the Vgs vs Id curves, for instance). In this simple test, one LED is first enabled by pulling the gate of its respective MOSFET low, a current pulse is generated by the inductor, and the discharge flows into the first LED. The second LED is then enabled and receives its current pulse:
This high-side switching could be used in two ways:
- A common-anode display could be driven directly with this circuit; the original test required a common-cathode display.
- High-side switching for common cathode displays combined with the original inductor-per-segment would drive multiplexed multi-digit displays. Since the duty cycle of the current pulses is already very low (0.025 - 0.05%), multiplexing can be done without affecting the perceived brightness.
I haven't built a circuit like this yet, - I'm still waiting for some suitable P-channel transistors, but from the simulation, it looks like it is going to work.
First Test
07/01/2017 at 20:33 • 0 commentsHere's a picture of the test board running off a CR2032 cell at 33.1 uA - but half of that is just being wasted in the PIC! (see below). This image was taken in a darkened room where the display is easily visible. It appears brighter in the image than in real life, though. In a brightly lit room, it can't be seen at all at these current levels, which are about the minimum the circuit can do as built. Overall, I would judge it to be too dim to be generally useful, unless you were only going to use it in the dark - a portable GPS-synched UTC astronomy clock, for instance (I keep thinking of this one, it might become a project).
The interesting part of the circuit is shown here (not shown are decoupling capacitors):
Each segment of the display is driven by a MOSFET and a 1mH inductor. The MOSFET gates are driven from PORTC of a PCI16F1718 microcontroller. To create a pulse of light from a segment, the corresponding MOSFET is driven, creating a ramp of current in the inductor. Once the desired current has been established in the inductor (just approximated by pulse length), the MOSFET is turned off, and the voltage across the inductor rises until the same current flows through an LED segment. This creates a sawtooth-shaped pulse of current through the display segment.
I used the PIC16F1718 because I had it on hand. Unfortunately, this part has an internal low-dropout regulator that draws 15 uA even during sleep mode (datasheet typical number). In my first tests, periodically waking every 32ms to pulse the segments, the PIC draws 16.4uA even when lighting no segments. Although you can disable the LDO during sleep, you pay a penalty in the wake-up time. I haven't measured it, but the delay is long enough to make the display flicker in a very annoying way. I really need to use an "LF" PIC variant. I like the '1718 overall, so I'll probably pick up some LF's with my next DigiKey order.
So, the first test was a simple assembly program that wakes every 32ms to create a current pulse of 8us. This is the lowest-power TritiLED mode. The code is a simple counter, incrementing the hexadecimal digit on the display every 255 timeouts of the WDT, or about every 8 seconds. This is long enough for me to measure the current draw with each digit displayed. Here are the results for digits 0-9:
Digit Current (uA) 0 34.6 1 21.7 2 31.6 3 31.7 4 26.4 5 29.4 6 33.1 7 26.4 8 36.8 9 31.1 I assume the current draw for digits with the same number of lit segments is slightly different due to the inductor tolerances. The average over all digits is 29.3 uA. Considering that over half of this is wasted in the PIC LDO during sleep, the results aren't that bad. It also means that you might get much more brightness for small incremental current increases.
Notes/Observations
This is the lowest current I can run with this circuit. I will experiment with running higher currents. It looks like something in the 100 uA range would make this display usable.
The red color isn't great for nighttime visibility. I found some very bright green displays (for $7.78 each!) on DigiKey. I think I will have to buy one. They're common anode, which will mean a re-think of the circuit - the easiest way might be to use P-channel MOSFETS. The green color should look much brighter to dark-adapted eyes, and these displays are about 2x brighter even in normal lighting.
The display can't be seen in normal room lighting, unless you add a red contrast enhancement filter. The problem with filters is that even though they improve contrast in some lighting, they always make the display darker. In a dark environment, contrast-enhancement filters make things worse. They certainly do in this case.
@Elliot Williams mentioned possibly just using a current-limiting resistor and PWM to drive LEDs at low brightness. This might be an easier alternative if the supply voltage was stable and always enough to light the LEDs. On the other hand, the inductor scheme can work with supply voltages down to the minimum of the PIC, 1.8V from the datasheet, and somewhat lower (off-label). Even with higher voltages, the inductor scheme might be more efficient than using resistors.
Here is the assembly test code:
#include <p16f1718.inc> ERRORLEVEL -302 ERRORLEVEL -305 __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BOREN_ON & _CLKOUTEN_OFF & _FCMEN_ON __CONFIG _CONFIG2, _WRT_ALL & _PPS1WAY_OFF & _ZCDDIS_ON & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LPBOR_OFF & _LVP_ON ;;; ;;; variables ;;; cblock 0x20 digit counter endc ;;; ;;; reset vector ;;; ORG 0 call SETUP_PERIPHERALS BANKSEL LATA movlw .63 movwf counter clrf digit MAIN_LOOP: decfsz counter bra PULSE movlw .255 movwf counter incf digit PULSE: movf digit, W call SEGMENT_LOOKUP movwf LATC ;; start pulse ;nop ;nop clrf LATC ;; end pulse sleep bra MAIN_LOOP SEGMENT_LOOKUP: andlw 0x0f addwf PCL retlw b'01111101' ; 0 retlw b'00101000' ; 1 retlw b'11100101' ; 2 retlw b'11101100' ; 3 retlw b'10111000' ; 4 retlw b'11011100' ; 5 retlw b'11011101' ; 6 retlw b'01101000' ; 7 retlw b'11111101' ; 8 retlw b'11111000' ; 9 retlw b'11111001' ; A retlw b'10011101' ; b retlw b'01010101' ; C retlw b'10101101' ; d retlw b'11010101' ; E retlw b'11010001' ; F SETUP_PERIPHERALS: ;; intosc 500 kHz BANKSEL OSCCON movlw b'00111010' movwf OSCCON ;; setup WDT for 16ms timeout movlw b'00001001' ; 16ms movlw b'00001011' ; 32ms movwf WDTCON ;; turn off LDO reg for low-power sleep ;BSF VREGCON, VREGPM ;; select digital I/O BANKSEL ANSELA clrf ANSELA clrf ANSELB clrf ANSELC ;; set TRIS bits: all outputs BANKSEL LATA clrf LATA clrf LATB clrf LATC BANKSEL TRISA clrf TRISA clrf TRISB clrf TRISC return END
