Ok, it seems that Autodesk has killed off the 'Freemium" version of EagleCAD. Well, that drops a large rock in the open source pond.
I learned EagleCAD on the Freemium license...ah well.
I added the 1:1 scaled PDFs in the files section to allow DIY toner Transfer PCB making of the double sided 5..5" x 3.25" PCB. Note that my layout has custom SMD pads for the TO247 IRFP3206 NFETS. Bend the Transistor leads at 90° just at the thick lead shoulder and trim down the bent section to 1/8".
I did that to make for an improved, low impedance solder joint that permits easy rework when experimenting with other transistors. It's a B*itch to remove through hole TO-247's without overheating the drain connection and lifting the PCB copper. Also, it provides for easy transistor realignment if you don't get your heatsink 6-32 mounting holes just right. Hot air is advisable, or solder wick when doing rework. I use a medium spade tip and about a 310°C setting on my solder station for the TO-247 rework.
290° C is ok for first installation.
As always, check out my other projects for DIY PCB making at home.
