If is not possible to fix your wheelchair wheel, or you don't find some replacement part for the wheels, using the toowheels hub's project you can create an hub for every kind of wheel (different diameters, numbers of spokes, size, etc..) with only some pipes and recycled bearings. Follow the instruction on the website or at hackaday project page!
![](https://cdn.hackaday.io/images/5137951507566292315.jpg)
