1Step 1
Order all components in the BOM. Generally, these do not need to come from the named suppliers.
2Step 2
Fabricate the few plastic components by 3D printing. Note these some are intentionally plastic for dampening, and should not be replaced with metal equivalents.
3Step 3
Explore the CAD model with SolidWorks or eDrawings (free of cost). Assemble sub-assemblies first (outer frame, linear thrusters, Z-axis couplings, etc).
4Step 4
Fabricate brackets for any tools desired. Anything compatible with an Arduino/RAMPS board is possible, including traditional FDM extruders, inkjet heads, lasers, milling spindles, probes, etc. Add a Raspberry Pi to drive even more complex tools, such as a microscope-projected DLP head.
5Step 5
Make something!
Matthew (mirage335) Hines
