All electronic components for upgrades
08/25/2017 at 17:01 • 0 comments0 Name of electronic components Number 1 HC-SR04 Ultrasonic sensor 1 2 Arduino pro mini 1 3 Module increases the voltage from 3.7 v to 7v 1 4 Battery 3.7v 300mah 1 5 4N60C Mosfet 1 6 A1015 Transistor 1 7 C2500 Transistor 1 8 Buzzer 1 9 Micro dc coin vibrator motor 2 10 Jack DC 1 11 Adapter 5v1a 1 12 Button 3 13 Led 1 14 Fr107 Diode 2 15 100k ohm Resistor 1 16 10k ohm Resistor 7 17 2.2k ohm Resistor 2 18 510 ohm Resistor 1 19 200 ohm Resistor 1 20 Small wire 1 21 "C1815 Transistor" 2 -
Selection of electronic components
08/25/2017 at 15:31 • 0 commentsI will supply voltage about 7 volt to Arduino pro mini on port RAW. This helps Arduino pro mini measure the battery voltage properly.
I use the voltage boost module.
The module lifts the voltage from 3.7v to 7v2a .
Or module to raise the voltage from 3.7v to the desired voltage.
C2500 Transistor used to turn on / off the charger. 4N60C Mosfet is used to turn on / off power (4N60C mosfet replaces Relay3v3a).
Start improving the product
08/20/2017 at 19:48 • 0 commentsThank you to the judges, who chose my project for the Best Product category.
I will start implementing the list below and make 3 copies of the product to send to the judges.
- Improved circuit diagram:
+ Replace Relay 3v3a with Mosfet 4N60C.
+ Use the voltage boost module (3.7V --> 7V). Used to power the Arduino pro mini.
+ The device automatically turns off the power when the voltage on the battery is less than 3.6 volts. (The device works well when the battery has a voltage greater than 3.6 volts).
+ Add 2 buttons " + , - " Used to set, increase or decrease the volume of Buzzer or vibrating motors. (Save settings to EEPROM).
+ Charge time (Poli 3.7v 300mah): From 3.6v to 4.2v is about 40 minutes.
- Edit program.
- Led on the front to catch the attention of the opposite person.
- Improved wrist strap more flexible, more comfortable.
- Add alarm function (Acts as an alarm device in the house. If there is a moving object it will emit sound).
The bracelet is fabric-covered and adjustable in size
07/19/2017 at 15:54 • 0 commentsI use elastic fabric to wrap the bracelet. Can take advantage of the socks
The bracelet, adjustable to fit more people's hands.
Can wear medium with the hands of more people.
I took advantage of the helmet and my socks. The strap is taken from another broken helmet.
Tiendo
