Python Code
07/12/2017 at 17:30 • 0 commentsI tried to get the the HX711 routine from the pigpio library working, but it kept stopping after a couple of minutes. This is what I ended up with. Occasionally, the data gets corrupted when the linux kernel interferes with the data transfer so it has to be processed to avoid big spikes in the data stream.
This code works at the physical layer -- bit banging the data from the HX711. It must be called after the DOUT line transitions to a low state, indicating that the HX711 has finished a conversion.
#!/usr/bin/env python3 #-*- coding:utf-8 -*- import RPi.GPIO as GPIO import time import math GPIO.setmode(GPIO.BCM) class HX711: """ Configured as just a 24-bit differential ADC """ def __init__(self, dout, pd_sck, gain=32): self.PD_SCK = pd_sck self.DOUT = dout GPIO.setup(self.PD_SCK, GPIO.OUT) GPIO.setup(self.DOUT, GPIO.IN) if gain is 128: self.GAIN = 1 elif gain is 64: self.GAIN = 3 elif gain is 32: self.GAIN = 2 #initialize GPIO.output(self.PD_SCK, False) time.sleep(0.4) # settle time GPIO.wait_for_edge(self.DOUT, GPIO.FALLING) self.read() def read(self): """ Clock in the data. PD_SCK must be low to keep the HX711 in an active state. The data from DOUT is clocked in on the falling edge of PD_SCK. Min PD_SCK high time = 0.2us, Max PD_SCK high time = 50us. Min PD_SCK low time = 0.2us. """ databits = [] for j in range(2, -1, -1): xbyte = 0x00 # intialize data byte for i in range(7, -1, -1): GPIO.output(self.PD_SCK, True) xbyte = xbyte | GPIO.input(self.DOUT) << i GPIO.output(self.PD_SCK, False) databits.append(xbyte) #set channel and gain factor for next reading for i in range(self.GAIN): GPIO.output(self.PD_SCK, True) GPIO.output(self.PD_SCK, False) # convert to integer from 2's complement bytes result = (databits[0] << 16) + (databits[1] << 8) + databits[2] if result > 8388607: result -= 16777216 return result def meanstdv(self, x): """ Calculate mean and standard deviation of data x[]: mean = {\sum_i x_i \over n} std = math.sqrt(\sum_i (x_i - mean)^2 \over n-1) """ n = len(x) mean, std = 0, 0 for a in x: mean += a mean = mean / float(n) for a in x: std += (a - mean)**2 if(n > 1): std = math.sqrt(std / float(n-1)) else: std = 0.0 return mean, std # test code if __name__ == '__main__': DOUT = 25 PD_SCK = 24 gain = 128 print("Gain = {}".format(gain)) hx = HX711(DOUT, PD_SCK, gain) while True: GPIO.wait_for_edge(DOUT, GPIO.FALLING) try: val = hx.read() print("value = {0} ".format(val)) except KeyboardInterrupt: GPIO.cleanup() GPIO.cleanup()An this is an example of how to use it, along with the pulse swallowing code.
#!/usr/bin/env python3 #-*- coding:utf-8 -*- ''' An example of getting data from the HX711 and swallowing artifacts. No guarantees that this particular code block will work, since I butchered it pretty heavily. There are additional processes (not shown) that processes the data into a seedlink stream and web server -- pretty esoteric -- I didn't think that there would be much interest. But the general method should be pretty clear. ''' from myHX711 import HX711 import time from datetime import datetime, timedelta, date from multiprocessing import Process, Manager import RPi.GPIO as GPIO GPIO.setmode(GPIO.BCM) # instantiate hx711 gain = 128 # allowed values: 128, 64, 32 print("gain = {}".format(gain)) DOUT = 25 PD_SCK = 24 RATE = 23 GPIO.setup(DOUT, GPIO.IN) GPIO.setup(RATE, GPIO.OUT) # set rate high (sample_rate = 28.94 Hz with 4.00 MHz xtal) GPIO.output(RATE, 1) hx = HX711(dout=DOUT, pd_sck=PD_SCK, gain=gain) # the Manager provides communication between processes. In this case between getData and the others. mgr = Manager() # makes a global list variable that is compatible with multiprocessing module. resultArray = mgr.list() def getData(): global resultArray, DOUT while True: GPIO.wait_for_edge(DOUT, GPIO.FALLING,bouncetime=1) tn = time.time() * 1000 # creates a unix timestamp with millisecond resolution Count = hx.read() # just returns the ADC result resultArray = signalProcessor(tn, Count, resultArray) if (len(resultArray) > int(sample_rate * 3600/2)): # store 1/2 hour of data # must use pop method for manager.list object instead of list=list[x:] method resultArray.pop(0) def signalProcessor(tn, data, rArray): ''' Pulse swallower: Swallow data, by using previous datapoint, if difference between Count(n-1) and Count(n) is greater than X, OR if the data = -1 (an indication that the data returned by the HX711 got clobbered.) Sample rate checker: Checks if period between samples is larger than Y. Kernal housekeeping obliterated an entire sample. This never happens at slower sample rates (< 30Hz). ''' if (len(rArray) > 2): prevData = rArray[-1][1] prevTime = rArray[-1][0] #if ( 1/20 < (tn - prevTime)/1000 or (tn - prevTime)/1000 < 1/35 ): if ( 1/20 < (tn - prevTime)/1000): print('Bad Sample Rate {0}. Index={1}'.format(1000/(tn - prevTime), len(seed))) for n in range(0, 2): rArray.append([tn, data]) return rArray if (((prevData - data)^2 > 3000^2 and prevData != rArray[-2][1]) or data == -1): rArray.append([tn, prevData]) print("{0} Swallowed Pulse {1}".format(datetime.now(),prevData - data)) else: rArray.append([tn, data]) else: rArray.append([tn, data]) return rArray def wiggle(): '''Makes a 10 minute square wave.''' GPIO.setup(22, GPIO.OUT) while True: print('LOW') GPIO.output(22, 0) time.sleep(60 * 5) print('HIGH') GPIO.output(22, 1) time.sleep(60 * 5) run_wiggle = Process(target=wiggle) run_wiggle.start() run_getData = Process(target=getData) run_getData.start() GPIO.cleanup() run_wiggle.join() run_getData.join() -
Shielding
07/11/2017 at 16:30 • 0 commentsThe inputs to the ADC are very sensitive to any kind of electrical interference. I recommend that you shield *everything*!
I wrapped the board in electrical tape and then covered it and the sensor leads with copper foil connected to GND.
This made a huge reduction in artifacts in the signal.
Results
07/10/2017 at 21:10 • 0 commentsI found the circuit to be quite sensitive to external disturbances and noise, so shielding everything is a very good idea. Here's a plot of a 4µVp-p 10-minute-period square wave injected directly into the HX711 channel #1 inputs with gain=128:
The measurement is in ADC counts. The input resistance was 10kΩ, so the 1µF input capacitor formed a 16Hz corner frequency. (At this point you should be asking yourself, "How did he inject a 4uV signal with a common mode offset of 1.65V?") The software can easily measure mean and standard deviation, so I estimate that the input referred noise is about 500nV p-p. That is on par with other amateur ADC systems designed for velocity sensors -- and compares favorably with ADC systems costing 100x more.
Bud Bennett
