Pixel Led Wifi Controller Tpm2.net
We develop a Esp8266 Wifi controller for more than 1500 pixel Led. Using the tpm2.net protocol it can be used with any dj software like JinX
We used only a Esp8266 and we could manage 1460 neo pixel leds (WS2182b) with tpm2.net.
Data input from led Ws2182b is conected to the D1 pin of thw Esp8266 NodeMcu AMICA.
We used: ESP8266WiFi.h, WiFiUdp.h and Adafruit_NeoPixel.h libraries.
The main body of the code is:
if (blocktype == 0xDA)
int packetindex;
if (cb >= framelength + 7 && packetBuffer[6 + framelength] == 0x36)
int i = 0;
packetindex = 6;
if(packagenum == 1)
led_index =0;
while(packetindex < (framelength + 6))
led.r=((int)packetBuffer[packetindex]);
led.g=((int)packetBuffer[packetindex+1]);
led.b=((int)packetBuffer[packetindex+2]);
pixels.setPixe
VID-20171030-WA0018.mp4
MPEG-4 Video - 8.92 MB - 11/07/2017 at 07:29
Download
WhatsApp Video 2017-06-27 at 16.43.28.3gpp
3gpp - 9.54 MB - 07/10/2017 at 20:06
Download
WhatsApp Video 2017-06-29 at 22.23.03.mp4
MPEG-4 Video - 6.14 MB - 07/10/2017 at 20:05
Download
WhatsApp Video 2017-06-27 at 16.59.53.3gpp
3gpp - 9.72 MB - 07/10/2017 at 20:05
Download
jinx-2.4.zip
Programa para hacer efectos y pasarlos via Tpm2.net
Zip Archive - 1.07 MB - 07/10/2017 at 20:04
Download
View all 6 files
  • 1 × Esp8266 WiFi Amica Nodemcu
  • 1000 × Led ws2812b
  • 1 × Power supply 12 v 20amp
edmund wrote 08/23/2020 at 07:46 point
Hi, great project, my problem: no  outpu (from Jinx?) I uncommented all "serials", wifi is connected (seen on serial monitor)  but then no serial messages any more, matrix is black , matrix is (54 *13) in Jinx are 2106 channels  organised as 702  x  3  What can I do?
Thanks in advance, Edmund
Dj Panchu wrote 06/27/2020 at 17:04 point
hola amigos. necesito esto pero que no sea IP FIJA.
mashoudul.plabon wrote 11/20/2019 at 12:29 point
Now i have a Esp8266 WiFi Amica Nodemcu . But Code is 100% upload no
error,  serial monitor not show ip address    WiFi is not connected .
how can i upload u code
mashoudul.plabon wrote 11/09/2019 at 20:15 point
dear
dear
echu1985 wrote 04/26/2019 at 00:07 point
Hola santira, como esta? tendrias la config que usas en Jinx?, tamaño de la matrix como config del tpm2, para la cantidad de canales? , estoy probando tu codigo pero no me funciona. un abrazo
Santira243 wrote 05/06/2019 at 01:24 point
Hola! En Jinx tenés que tener en cuenta que cada led ocupa 3 canales! Y lo máximo por canales es 1354. Si tenés 100 led tenés que configurarlo como 300 canales. Espero que funcione así
echu1985 wrote 05/06/2019 at 02:11 point
Mucha gracias por la ayuda genio, por suerte ya lo tengo funcionando pero tengo algunos fallos que resolver, no se si te paso tambien, por ejemplo cuando enciendo todo se queda colgada la ESP8266, tengo que darle tension primero a la placa y un vez que conecta  la red, ahi enchufar los leds, sino no arranca, y despues cada tanto tiene unos tirones con cualquier efecto que ponga y lo hace aleatorio, como una caida de fps. probe otro router, otra pc, pero me esta volviendo loco jaja. un abrazo!!
Santira243 wrote 05/06/2019 at 12:09 point
Si, varios hemos experimentado ese problema con muchos led. Es un problema que no pude resolver, estuve luchando bastante con el código pero lo sigue haciendo. Si lo resolves te pido lo compartas. Anda bien hasta que de pronto pluff... Se cae. Y después retoma pero más lento.
nah wrote 08/16/2018 at 16:09 point
hola intente controlar 1200 pixels dividido en 3 bloques.. funciona pero da un reset cada tanto
Exception (29):
epc1=0x4000e1b2 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffce0 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffe80:  3fff2bfc 0000002c 00000000 401004f4
3ffffe90:  4021147e 4021143c 00000000 40107088
3ffffea0:  60000600 00000000 3ffea144 402114bf
3ffffeb0:  40000f83 00000030 00000011 ffffffff
3ffffec0:  40000f3d 00000023 00000000 3fffd9d0
3ffffed0:  00000000 00000000 00000000 fffffffe
3ffffee0:  ffffffff 3fffc6fc 00000001 3fffdab0
3ffffef0:  00000000 3fffdad0 3ffeea50 00000030
3fffff00:  00000000 4020f185 3ffed670 4021143c
3fffff10:  3fff2bfc 3ffea1d6 3fff2bfc 40211446
3fffff20:  3ffed670 00000000 0000000d 3ffeddb8
3fffff30:  4020f203 3ffed670 3fff2bfc 00000000
3fffff40:  4020efd3 3ffed688 3ffedde0 01f41539
3fffff50:  00000000 3ffed688 3ffedde0 01f41539
3fffff60:  4020f47c 009c25d4 3ffedde0 60000600
3fffff70:  40219ad1 3ffed688 3ffedde0 01f3e9af
3fffff80:  40219b16 3fffdab0 00000000 3fffdcb0
3fffff90:  3ffeddf0 3fffdad0 3ffeea50 40203467
3fffffa0:  40000f49 40000f49 3fffdab0 40000f49
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
no entiendo por q razon .. tal ves estoy configurando mal el jinx?
gracias
nah wrote 07/29/2018 at 06:10 point
hola santira.. estoy implementando tu codigo.. pero no susede nada.. estoy compartiendo las masas. conectando todo al pin D1 pero no susede absoluta mente nada.. en que podria estar fallando?? saludos
Santira243 wrote 07/29/2018 at 14:49 point
Es muy probable que el problema sea la configuración de jinx. Mándame una foto por privado de la captura de pantalla (sromeroayala@teembu.com)
nah wrote 08/06/2018 at 01:07 point
ok mail enviado.. gracias
jeremy.leroy wrote 07/08/2018 at 07:54 point
Wow, really good job, and very impressed you used 1600 pixel on 1 output.
Do you think it's possible to use your technic with xlights program, for christmas lights?
Thanks for your good job :)
Santira243 wrote 07/08/2018 at 14:27 point
Hi I never used xlights but I ll check it. We tested 1460 pixel, not sure if can manage 1600 due to a buffer limit. Thanks for your comment
jeremy.leroy wrote 07/08/2018 at 14:46 point
Hi, thanks for your reply. My goal is 1000 pixel with 1 ESP8266, but with Xlights. Jinx is very good program, but not for christmas lights.
With arduino, I never exceed 480 pixel i think, That's why i tested with ESP now.
If you find solution, or find a track to help me in this goal, I would be very happy.
https://xlights.org/
Thanks
Santira243 wrote 07/08/2018 at 14:41 point
Hi, I think xlights don't have tpm2.net protocol for using with this software
Santira243 wrote 07/08/2018 at 18:13 point
You have two ways to make your project. One is to ask the xlights Creators for implementing tpm2.net protocol compatibility. Or to implement a DMX protocol in the esp8266 like this https://github.com/forkineye/E131
fevzi hayırlı wrote 05/22/2018 at 08:14 point
thank you.
Paket boyutu için # 600 piksel matrisi = 1357 böyle bir erişim.
1357 sabit mi?
Santira243 wrote 05/27/2018 at 12:38 point
1357 sabit değil, değiştirilebilir ama alabileceği maksimum değer. 600 piksel için, piksel başına 1 kanonun olduğunu düşünmeniz gerekiyor, bu yüzden 1800 pakete ihtiyacınız var. 1357'de varsa, pikselleri "yenilemek" için iki tam paket alacaksınız.
Santira243 wrote 05/22/2018 at 00:35 point
Great Work!!!  #define packet_size = 1357; this is defined in JINX.
Santira243 wrote 05/22/2018 at 00:38 point
but too much latency and pixel jumps... I saw the video... I think is some problem with your computer processor or may be the router connection.
fevzi hayırlı wrote 05/02/2018 at 21:44 point
hi
please help me!!!
I tried, but too much latency and pixel jumps.
I have a mistake or missing somewhere.
my pixel screen , 40x15=600 pixel  1800 channel
jinx! software or code    chan/blok= ?
code                              #define packet_size =?
fevzihayirli2014@hotmail.com
thanks.
fevzi hayırlı wrote 05/01/2018 at 12:20 point
what?
diegorabbia wrote 01/25/2018 at 01:40 point
1.buenas noches, estuvieron probando Este codigo Mismo Con El Esp8266 Wi-Fi? andan hasta 1200 2812b
matzeb74 wrote 12/14/2017 at 23:20 point
Hello, i just tried this out and must say it´s great. I´ve build a Matrix with 150 ws2813. I´ve two problems.
First Problem ist that my first 2 LED always flicker in another Color every two seconds. They Flicker always in red. Looks similar to a Statuslight. I don´t know why.
Second Problem is that my Matrix has not the right Colors at all and after running a few minutes the whole Matrix is going crazy. If i use Jinx in wired Mode, then the Matrix runs stable for hours. Maybe u know how to solve the Problems.
Greetz
Beliar
Santira243 wrote 10/29/2017 at 02:25 point
Thanks Emilio!! When you said: " Talking about Jinx i could also understand that you should assgin 3 bits for each led (R G B)" its important to mention that if you have 30 leds, then in jinx you have to assign 90 channel.
Emilio wrote 10/26/2017 at 11:53 point
Thanks for ypur  predisposition and collaboration to help me connect and configuate the nodemcu and led´s strip
it was not so complex but for begginers as me it could be a little bit dificult
I did configurate the wifi led and assignesd  an ip modifying th code line
IPAddress ip(192,168,8,120);
IPAddress gateway(192,168,8,1);
 and taking out the comment of the line where the variables are defined
WiFi.config(ip,gateway,subnet);
I´ll be making more tests with more  quantity of leds strip
It was a pleacere to be in touch with you  and to  get into arduino´s programmation world
cheers
