Cemented switch
All the adapters were drilled with a countersinking bit so countersunk screws could neatly attach the plate to the pipe. The pipe was drilled with a small bit and short screws were inserted at the corners of the adapter.
Attached adapter plate
Once everything was mounted, the trigger was tested. Even though the cement had only been drying for an hour, the stability was good and the trigger tested well. The most notable problem was that the trigger and handle were far apart. Someone with small hands or short fingers may have trouble pulling the trigger.
Trigger testing
