On the schematic you will find one chanel of this amplifier so basically you need second one to have a stereo sound in your headphone.
Each tube have to identical section inside so you need basicaly one ECC88 (V1) and one 6H13C(V2).Input stage I used quite good quality Alps 100KAX2 potenciometer with good compromise quality/price.
At this moment I've rebuild little bit filament for tubes and power supply for filament is 6.3VAC directly from the transformer.
Ha, I wondered about the E88CC designation, and why not ECC88. According to http://www.r-type.org/exhib/aaa0037.htm :
The E88CC is a special quality double triode. The transposition of the figures from the end of the type designation to the middle was Mullard's way of denoting a special quality build.
Learn something everyday.
